DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Feb 7, 2018 at 9:40 AM Post #11,116 of 22,021
@jessnie : Could you take a picture when 4.4 mm. plug into, and a 4.4 mm. plug doesn't nip your miter case? From the aboved twister6's pictures, it should nip.
It does nip the miter case a bit, but what I was saying is that it doesn't prevent you from plugging in the jack and the extent of the nipping doesn't bother me at all.
Feb 7, 2018 at 11:26 AM Post #11,118 of 22,021
I actually phoned them a couple of minutes ago, apparently they were told production of amp4 will resume after the chinese new year. But nothing has been confirmed yet by ibasso. So they're hoping to get a word from ibasso after chinese new year.
Feb 8, 2018 at 12:17 AM Post #11,123 of 22,021
Anyone from NYC here going to the CanJam? I'll be working the iBasso table with Jamato.
Feb 8, 2018 at 2:00 AM Post #11,124 of 22,021
I have a question this is from HiBy:
i talked with paul before and he said DX200 have '' DTA '' that is Bit perfect in android.. what happen here?
Feb 8, 2018 at 2:07 AM Post #11,125 of 22,021
Curious question, has anybody tried DX200 vs hiby r6 yet?
Feb 8, 2018 at 2:16 AM Post #11,126 of 22,021
Feb 8, 2018 at 2:53 AM Post #11,127 of 22,021
Not fair marketing from HyBy side. "DTA" in R6 is no better than in DX200. Considering that HiBy didn't mention DSD in their table, "DTA" in R6 is worse: DX200 allows 3rd party apps to playback native DSD, and R6 does not.
Please remember: whatever claims you read from HiBy, bear in mind that Android API does not provide an opportunity for bit perfect playback of 24 and 32 bit integer samples! All that HiBy claims is only applicable to sample rates. There is no a way for bit perfect playback of 32/384 using only Android standard API!
On the other hand, DX200 does provide a way for 100% bit perfect playback of any PCM (up to 32/384) and DSD (up to DSD256 via DoP), without modifications of apps. HiBy Music is the example of such an app :D
The bottom line is: iBasso DX200 is the first, and still is the only DAP in the world, which allows the feature called "DTA" by HiBy. OK, with my firmware, but it does not really matter, because for any other DAP there is no a way at all.
And, just in case...
Considering SoC used, they are not fair here as well. The correct values are: "4xA53 cores" for R6 and "8xA53 cores" for DX200 :)
3GB of RAM? Increase of the cost and power consumption, and no real benefits.
So, R6 is only better than DX200 by "stainless steel frame" and QC3.0, and worse in each and every other row in the table, excluding screen resolution, which is equal.
