Bastianpp
- Aug 11, 2016
I use a parametric eq in Tidal desktop, someone know a parametric eq for Tidal mobile ( direct into dx200 ) ?
It's possible?
It's possible?
Here it is, review and comparison of iBasso AMP3, AMP4, AMP5, along with CA01 and CA02 cable adapters: https://twister6.com/2017/12/01/ibasso-amp3-amp4-and-amp5-modules-for-dx200/
Having read through your review, it seems that AMP5 is an upgrade to AMP2.
While I'm okay with AMP5 being a sidegrade to AMP2, I feel cheated by iBasso if AMP5 is significantly better than AMP2.
The reason why I jumped the gun with AMP2 because I thought that AMP would be intended more for an inefficient headphone, with less stellar battery life, which for my IEM use would not be that useful. Alas, I was wrong.
Nobody cheated anybody. Amp5 is a newer amp module , and so what is the point of new product that offers nothing new ?
Maybe Ibasso should just do sidegrade to your amp 2 and satisfy you alone, then having products on their hands that can not get sold to generate revenue and move on with newer products. Make a lot of senses huh ?
I don’t read AMP5 as an upgrade to AMP2, but more as a more powerful single ended option compared to amp1 (minus of course all the differences in tuning)
AMP2 is still the most musical and organic of the bunch which makes it very precious, and I use it extensively
Yes, this is precisely the response that I'm waiting for.
My initial statement is not meant that it is a fact, but something of a possibility. And I'm really grateful for having feedback from a user like you
It would be interesting to have a comparison between Amp2 and Amp5 as from what I read the sound signatures are similar (but the Amp5 is more powerful and battery lasts more). what are the differences in sound using them with efficient IEMs?
Yes please! @twister6
A more direct comparison would be much appreciated. My take on it was that it still has the same warmer tonality of AMP2, but AMP5 improves on it. Thinking of ordering AMP5 now...
AMP4 having an even wider soundstage and blacker background sounds interesting. Not sure about the more revealing upper mids and lower treble. I wish there was an L-shaped adapter though, so I won't have so much sticking out. I feel like I would brake the amp if I pushed it sideways on accident.
