- Oct 14, 2013
Wow, Just announced on iBasso's Facebook.
Holy, moly, gold-y goodies....jeez....I want it!
What does the 'cu' mean?
I dunno i like the stock colour better. Looks more stylish and sofisticated and not cheapish and bling
Are the Amp modules going to come in multiple colors now as well? Otherwise it would be quite a stylistic mismatch.
Hahah maybe... I'm sure iBasso has figured out a more elegant solution than having us dip the Amp modules to try match the precise color and finish they use on the new shellsWell, those amp modules will be released in limited number just like the Cu version itself I guess ? Unless you want to dip in those special modules as well for your regular version, then that is your doing
So there is standard aluminium, will be titanium, and copper gold plated. Probably the amplifier modules will come in same materials. Good to have so many options to choose from.
Final thing left: more internal memory at least 128 GB.
Many AK fans will be switching to Ibasso, i have a feeling
It isn't all bling. I listened a lot to the titanium version at CanJam and while the internals were the same as the DX200 aluminum the sound was not. It has to be how it shields and the ground difference. I found the titanium a little more transparent and an even slightly more black background. There is an affect on the signal using these different materials so I wouldn't be quick to say it is done for bling. I would guess they gold plated the copper for oxidation reasons but you would have to ask them.They look so ghetto bling. It looks like a DAP dedicated to some rapper. LOL.
This brings iBasso creds down for me. I was hoping they wouldn't stoop so low like AK. It makes seem like you are a buncha suckaas(especially if you carry that around).
By the time they release casing with different metals they should release FW that fixes the annoying song head cut thing, plaese.So there is standard aluminium, will be titanium, and copper gold plated. Probably the amplifier modules will come in same materials. Good to have so many options to choose from.
