Our latest Firmware for the DX200 2.4.135
Improvements with this firmware:
1. Rectified the bug that when charging or in sleep mode, the DX200 has a small possibility to reboot.
2. Rectified the bug that sometimes when playing music, the DX200 automatically pauses or the Launcher crashed. (Android OS)
3. Updated the playlist import and export function.
4. Rectified the bug in the first minute of using the DAC function, the DAC might disconnect from computer automatically.
5. Rectified the bug that system error happens when using the Japanese input. (Android OS)
6. Rectified the bug that when playing some APE music, the tracking number showed as 0/0. (Android OS)
7. Rectified the bug that when playing DSD music, pressing the tactile buttons would introduce noise. (Android OS)
8. Rectified the bug that when playing from Directory view, the Now Playing track order is different to the track order of theDirectory view. (Android OS)
9. Rectified the bug that when playing some DSD music file, the sound stutters. (Mango OS)
10. Rectified the bug that when playing some specified music format, the system becomes slow to respond. (Mango OS)
11. Rectified the bug that when playing some CD image or ISO, the album artwork can't be displayed.
12. Rectified the bug that when playing from Genre view, and returning from secondary structure, there is nothing displayed.
13. Updated FLAC decode engine, and improved FLAC support.
Instruction For Firmware update:
1. Copy and paste the DX200-2.4.135-ota.zip to your SD card's root folder. (extraction is not needed, place zip file directly on the card)
2. Go to Android OS, press Settings-->About DX200-->System updates-->local update-->default and tap the zip file.
3. The whole update will take about 10 minutes. Reboot the DX200 after update completed.
