LCMusicLover
Hope, morning's mist rises
Bitter wind sweeps dreams aside
Again, out of stock
Again, out of stock
I know cost is a taboo subject on Head-fi, but not really a toss up if you consider DX200 is double the price. I'm still waiting to hear both before I decide if the DX200 is worth paying the extra for the type of sound/music I like. X5III not in UK yet & DX200 difficult to find anywhere in stock but do have both pre-ordered so looking forward to comparing as not had a dedicated DAP since having a ZX2.
maybe somebody reported this but...
software problems:
mango - brigthness level is backing to deafault after screen off/on
mango - fully unloaded battery is reseting card scannig results and rescan is necessery
android - adjusting sound level in mango player is comfortable and precise but in other applications like tidal, spotify it is not so precise... and by mistake you can adjust it to a full level just by one touch... it is pain for ears...
2.4 gHz WiFi working cause very gentle hiss, left channel only, independent from sound level/amp section
no discription of the digital filters in pdf instruction of player
Same problem with 2.4 gHz Wifi
But the most irritating thing is the laggy/buggy top bar on android mod. The top bar is so unresponsive.
That's right. I'm finding it really hard to get top bar rolled out. 1 out of 5 is getting successful I think.
software problems:
Anyone else have 2.4GHz Wi-Fi hiss\noise?
I would add another. Brihhtness on lowest setting is too high for using in a dark room. Both Mango and android.
Yes, it was mentioned here before.
software problems:
Stay updated on iBasso at their sponsor profile on Head-Fi.
