Is there any way in Mango mode to change the default name of the Playlists? I don’t like to create playlists if afterwards I don’t know which kind of music is within each one.
Thanks Paul.
It´s a good option, but I would prefer to change the name directly on the DAP, since I don´t always have a computer close to me. Maybe you can add this option in further firmware updates.
Cheers.
Try playing your music library files through UAPP instead of Mango. I have been unsuccessful in getting USB out without the use of UAPP even using an OTG cable such as yours. I am also running Lurkers firmware add-on to Oreo.
Wanted to ask what capacitor would you guys recomend for amp1 Mod, was thinking of getting 470uf or 220uf nichicon Muse fg, would these be ok? Or has anyone suggestions of better ones.
I successfully ported DX220 ROM to DX200 unit yesterday. New iBasso Music app looks pretty neat and sounds more analogue than current MangoPlayer in the same DX220 ROM.
So far most things are working fine with DX220 MangoPlayer except rapid track changing is lagging and brick wall filter can't be used (set to 6 and crash if you change in Settings).
I hope next DX200 will use the same one as DX220. I can't go back to DX200 MangoPlayer sound anymore. I know something's not right and my favorite sound from 2.3 isn't updated until this one.
From where can we download the firmware?
