Without TDK capacitor?Let it burning in for awhile to see if the harsh goes away.
How long?
Im burning in it for about 40h.
How long?
I meant polarity and legs and other meaningful things))Did you mean to ask the correct polarity +/- ?
If so, MLCC has no polarity, just put it on, make sure you don’t short them together by crossing the legs with other legs
for how long?Yes, I recommend burn in without TDK..
How long?
I think the better explanation is a good quality photo of this part of board(in red circle)
So I should solder TDK on these two pads just don't touch another legs. Without polarity.(blue is TDK)Ok, this is Amp8-EX, but don’t worry about it.
There are 2 big capacitors in green and plum color, the TDK should go in those pads, and make sure the - does not touch the + from all 3 Capacitors. There may be a risk of them shorting out by this meaning, just make sure you are in the clear of separating - and +
** see how the black lines are almost touching the + of the plum capacitor leg ? Do not let it happen, period
All 3 legs on 2 theese pads should go separately.
Am i right?
And I dont see any black line touching the + of the plum capacitor leg))
Thanks. I give it a tryYes
Yes
Yes! Just almost* as an example picture of what may happen
It's the amp 3can i ask which is the musical amp module, with 2.5 mm balanced
Guys, @Whitigir , @EggofSound
reading this
ok
about the orange replacement I think it's the easiest to do.
But what about the 4 grey replacement? what does it mean the "tantalum is positive and not negative"? I will ask to some welder to do the work for me to avoid problem but I want to know some more information to inform me to be sure to do everything right.
Thank you.
Electrolytic capacitors have a - mark.
Tantalum capacitor polarity mark is marked with a +.
Tantalum is marked in reverse, so be careful.
Because tantalum con breaks down in short mode, damage will extend to the surrounding circuit parts, so I think that it is so because it emphasizes the positive pole in particular.
