Vitaly2017
Muse Nichicon was in your amp4s. You shouldn’t change it, because it improves further upon what the 4S was (and not tuning it into a slight different like Amp8). In my opinion at least
Do you have a link?
Interesting, I just had a 45mn audition... yeah the bass and mids were smooth detailed and very organic, I had an issue with the trebles though or at least my impression was that the SP1000 was less forgiving of average or bad mastering than the DX200. On good recordings and well mastered stuff, smooth all the way. It could make it less of an all rounder than DX200 in that respect. Also, I don't think the SP1000 has a reference signature, as it's not really neutral. But no hiss for sure and a very impressive black background.
I don’t have a Mouser Link, you can look up UKW Muse. Gold-black jacket
Yyaaap thats the one. So this is muse nichicon. Quick question why there is 2 like that soldered into 1 socket? Was it initialy 2 as well?
To further improve upon Amp4S sound signatures performances. No
They are too big to fit in the Amp modules. With the design of Dx200 and it amp modules. We are lucky to be able to have juicy electrolytic capacitors. I don’t think LPGT or SP1000 has any of them. There are some special characteristics that only Electrolytic capacitors can bring. Tantalum and MLCC can not do so, and vice versa. It is totally awesome to have them all in the DX200whitigir@yahoo.com did you try using mundorf caps or blackgate if you can get hold of them?
If you're going to RMAF Denver Canjam, do try to get a prolonged audition with the R2R2000 with your own music/ microsd card on your Legend X. I'd love to hear your thoughts about it.
Lol! We are all becoming a broken records =/ re-re-re-peat! On everything through-out the forum lol. But I can see how irritated you are lolThat's assuming the next R2r2k fw update will keep DAP functionality, since they are flip'flopping between USB dac and DAP
Never mind, it is the Xu216 that is able to do 768Khz and not 208
Wait, you are correct. The Xmos208 can take 768KHz. I really wonder if Ibasso will release firmware to allow it to do 768KHz for the future. For now it is at 384Khz onlyProbably a bit off-topic, though related to your question, I was looking at the spec of AK4137EQ Pro SRC upsampling chip (feel free to PM me if you want to play the guessing game Vince), and I also noticed while it supports up to 768kHz PCM and DSD512 hardware upsampling, manufacturer/s like to cap it at only 384kHz and DSD256, so I was wondering about limitation as well. Ok, back on-topic!
**The sub-bass will be affected, the rest of the bass will remain**
Swap out the Siemens cap by this Nichicon. The sub-bass will be more coherent to the rest of the bass lines and be more balanced but won’t be lacking the slams and punches, the warmth will be tamed down. It will also be very revealing and layering similar to Amp1Ti. Especially that trebles airiness and extensions. On bad records, you would yank out the headphones and want to delete it right away (0 tolerances whatsoever for such)
https://www.mouser.com/ProductDetail/647-RNE1C471MDN1PX
If you want to tame down those, which I had to because I am using hd800S. I put in this . Mouser is out of them, get something else at similar value
https://www.mouser.com/ProductDetail/KEMET/C331C105K5R5TA?qs=sGAEpiMZZMt3KoXD5rJ2N8Niw/lusg%2b5crGuHhWRlR0=
Btw, don’t ask me if I just used any cap value at random....no....I used them for a reason, and judge them (improvements) by ears. In this hobby, if I don’t judge them by ears, I would have quit a long time ago.
