- Oct 14, 2013
He isn’t lucky....he is just extremely richYou are so lucky to have both! I would love to hear the 1Z. Can you compare the two and let us know which you prefer and why please? Thank you!
Yes, it is unusual but technically speaking, it is the best configurations. Music reproductions for iems and or headphones always interest me. The reason why they opt for this way Is because BA is better for the upper low-mid range rather than high frequencies as people has been mislead into. Then the limitations is that sub-bass isn’t too well performed with BA. Therefore Sony went with this configuration in Z1R. I don’t know what they marketing with but the ideal configurations for any good BA would be that the BA is upper low and full mid range. Sub bass and high frequencies are better jobs for dynamic
I am too impatient waiting for Ibasso to release type C audio grade usb cables. I have just ordered with Moon-Audio. This will complete my Dx200Ti configurations .
On another note, I did make a mistake of reviewing Dx200 without using IEMS. As the result, I sold my Dx200 detailed that it has no problems....but it hiss with some people IEMS. My apologies that I did not foresee this. But then again, I am only an enthusiast and Not sponsored Reviewer where I can get items sponsored and test out everything for you guys. But you know that you will always get the honest impressions from me and what I can afford to do
After couple days of listening to the bespoke Ares II 8 wire 4.4 paired with Spartans and DX200TI/amp4s and I just try to listen with DX200TI/amp8 to be honest Ares II 8wire might match well DX200TI/amp4s (have not done with amp8 yet!) with thick and rich sweetest vocals especially the huge soundstage with lots of details and separation of music instruments...sub bass and deep bass are there too. Oh man! I wish I have CIEM Phantoms right now...
You think it matches better with amp4s better than amp8? I though amp8 had more bass and warmer sounding.
Hey do hear floor noise? With your setup on amp4s or amp8?
I have not yet tried DX200TI with amp8 since I am enjoying the sound of amp4s right now.
Absolutely no floor noises at all! It is dead quiet...
What you use iem or headphones?
CIEM Spartans IV.
That is why I am on hold to order the Phantoms...
Then why mine does noise. Means its broken?
What do you have now? IEMs or Hp?
That's not normal. I've used the Phantom on Amp 1, 3, 4, and 8 - no noise on any of them. Contact Paul.Ihave noise that is quoet loud with phantom
My shure se846 does the floir noise but not loud to be a problem
Hd800s dont catch it at all 0 issues
Its like a white noise its low bur very audible quiet frankly.
Bothe amp1 and amp4s do it with phantom.
And on my desktop i get no noise at all same gear
