DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Jul 25, 2018 at 7:36 PM Post #15,632 of 22,021
No, you can't turn unbalanced cable balanced. You can turn balanced cable into unbalanced by an adapter but not the other way around.
Thank you, I appreciate it.
Anyone any advice on a cheap 4.4mm balanced cable? Nothing fancy just a get the job done cable while I save up for a better
Jul 25, 2018 at 7:41 PM Post #15,636 of 22,021
Just cut 3.5mm plug and reterminate with 4.4 plug.
Jul 25, 2018 at 7:45 PM Post #15,639 of 22,021
I like Lindsay's cables from Impact Audio. He's on Etsy. But he's on vacation right now.
What's your budget?
For now a measly 50$ or less, lmao!
Saving up for a better cable from Effect audio as I like their stuff. But a need a cheapo cable to hold me over
Jul 25, 2018 at 7:52 PM Post #15,640 of 22,021
Hey there's a cable for everyone out there.
**** has a few on Amazon that get good reviews. YMMV.
https://www.amazon.com/****-Detachable-Replacement-Headphone-Black-MM4-4/dp/B07D4G772M/ref=mp_s_a_1_1?ie=UTF8&qid=1532562567&sr=8-1-spons&pi=AC_SX236_SY340_FMwebp_QL65&keywords=iem+cable+4.4mm&psc=1&th=1
https://www.amazon.com/****-Silver-Detachable-Replacement-Silver-MM4-4/dp/B07D4DHLY3/ref=mp_s_a_1_2?ie=UTF8&qid=1532562567&sr=8-2-spons&pi=AC_SX236_SY340_FMwebp_QL65&keywords=iem+cable+4.4mm&psc=1&th=1
Jul 25, 2018 at 7:54 PM Post #15,641 of 22,021
Those are balanced right? And won't damage my iems?
Jul 25, 2018 at 8:45 PM Post #15,643 of 22,021
What is the sound difference between amp4 and amp4s?
assuming you're planning to buy a used one? cause both are discontinued. The only new amp modules listed on iBasso website are amp3, amp5, amp7, and amp8.
Jul 25, 2018 at 8:59 PM Post #15,645 of 22,021
