linux4ever
If any body know of any retailer stocking Dx200ti in USA or if for any reason you might want to sell your dx200ti, please pm me.
Thanks!
Thanks!
Thanks!
Yes I did. No USA distributor bought dx200ti. So none available in USA.
I thought somebody mentioned a Europe distributor taking pre-order on this thread yesterday.
And the beautiful search feature of this forum doesn't bring that out.
Lol, typical 3rd party cables vendor . Are u sure the channels is correct ? LoL
I agree, but you know what I mean . Just like anything in life, there are always some bad fishes in the pondsIt depends on which third party cable that is not too cheap. I use balanced Triton Audio cable which surprisingly sounds so good and absolutely not too fancy one...
Stay updated on iBasso at their sponsor profile on Head-Fi.
Heat. If the DX needs a charge that will generate some heat. If you are playing regular resolution files that isn't a problem. But if you are charging the battery and using higher resolution files, there will be much more heat generated. This has to be taken into account. There is a lot going on inside of the DX200. If you have a full battery charge and are using the charger then heat will be less of an issue since the battery is already charged. But charging and using high resolution music can be an issue. Surrounding ambient air temperature and air circulation around the DX needs to be taken into account.
If you get a phone cooler the heat will be a moot point. Laptop coolers work well too.Excellent ! Thanks for the “clarification”. This means
1/ Do not use DSD512 and charge simultaneously, especially Dx200Ti
2/ Best to use DSD512 running on battery only and or charge only. Also, take it out of the Case!
No problem! 4 hours of playing back DSD512 on the Dx200 driving HD800s is already too good to complain
I use opened back headphones and I don’t listen too loud, just enough, and fan noises will kill it for me LoL. Probably an ice packIf you get a phone cooler the heat will be a moot point. Laptop coolers work well too.
This might work for you...I use opened back headphones and I don’t listen too loud, just enough, and fan noises will kill it for me LoL. Probably an ice pack
So are all the current Ti owners stocking with the Ti AMP 1 or changing it? I haven’t bothered putting my AMP 4 back in so debating whether I should sell it or just hang on to it.
I'm using AMP8 for my daily driver and swapping to AMP1Ti to burn it in at night.So are all the current Ti owners stocking with the Ti AMP 1 or changing it? I haven’t bothered putting my AMP 4 back in so debating whether I should sell it or just hang on to it.
