Dunu-Topsound Studio?
- Thread starter H T T
davidmolliere
@vilhelm44 I love that R8/OSG/SA6 combo agreed and the blue on your shells
if you can take further pics
vilhelm44
- Feb 9, 2014
- Messages
- 961
- Reaction score
- 401
It's a fantastic combo indeed. I would have been happy with any colour really but I lucked out with that blue. I'll take some more pics tomorrow when the light is better@vilhelm44 I love that R8/OSG/SA6 combo agreed and the blue on your shellsif you can take further pics
Bass sounding that way is also an advantage for me ...... Are there other IEMs that have bass sounding that way? Or in any case with the same low range of the SA, perhaps with a higher quality in general also on the other ranges?DM8 seems to be using the same vented Sonion woofer as the SA6, but it's just the single woofer vs 2 of them on the SA6. Positioned at a lower level than the SA6 IMO. Speaking of woofers, SA6's bass response caught me off-guard with the switch flicked on. They sound close to a well-tuned DD with the slam and dynamics. It does lack the texture and gut-wrenching rumble of some of the bassy DD drivers I've heard/owned but they don't sound like BA bass for the most part and I consider that a huge positive for my tastes.
HiFlight
I received my SA6 yesterday and was very pleased with the color (which I will post pix later). Unfortunately, with my ear anatomy, I am only able to successfully use large shallow fit tips. I found that none of my tip stash gave a secure fit that provided an adequate seal. I first blamed the problem on the short nozzle but after a lot of fiddling, I discovered that the hefty cable was the culprit.
I wish Dunu had adapted the 17th Anniv. cable for use with the SA6 as it is quite supple and performs superbly.
Just got mine in today as well. I had requested a green & yellow faceplate from Linsoul and they seemed to be able to accommodate it, but I still ended up with a mix of yellow, orange & blue instead; still beautiful. Will post pics later. I don't think it's possible to get an "ugly" SA6.
Mine arrived today! First, a picture:
Secondly, they fit into my ears perfectly with the tips already on as they arrived but I’ll be playing around with some others later.
I may like the sound more with the switches set to “1” but need more time.
Anyone have a spare size small of those Acoustunes 08 tips they’d sell me?
Lastly, the cable is mostly great but I find the top of my left ear just where the cable touches it as the loop over starts exerts a bit more pressure than is comfortable. Any suggestions? Maybe I just need to bend back the cable a bit so it doesn’t curl so tight?
davidmolliere
Beauties!
phthora
When did you all order your SA6? I ordered mine on the 8th, and they have yet to ship from Linsoul. I get the 11/11 rush and delays, but I'm starting to get a little annoyed over here.
vilhelm44
- Feb 9, 2014
- Messages
- 961
- Reaction score
- 401
If I had a small Acoustunes 08a size, I'd send you some but onlu have large I'm afraid. It's worth picking some up though, they work a treat.Mine arrived today! First, a picture:
frix
- May 7, 2012
- Messages
- 382
- Reaction score
- 124
Can someone tell if the vent does help reducing the vacuum/suction feeling?
I ordered the same day as you. I received initial tracking info on the 17th. From there it took only 3 days to leave their warehouse in mainland China to HK to clearing customs/NY & I received it on the 20th. Have you reached out to Linsoul? They were pretty responsive when I emailed them about the faceplates.When did you all order your SA6? I ordered mine on the 8th, and they have yet to ship from Linsoul. I get the 11/11 rush and delays, but I'm starting to get a little annoyed over here.
I purposely avoided listening to these last night as I needed some much needed sleep & didn’t want to get sucked into a late night listening session (as impressions/reviews suggested I would), but I’ve had these in my ears since waking this morning and I am loving them. Decided I’d ease into the day so I put Agnes Obel on shuffle (FiiO M15 on SE); left-right stereo imaging, instrument separation, resolution & staging are excellent. Will try other artists/genres later as Agnes Obel tends to be more intimate as opposed to concert staging. On a related note, I had no issues using these in bed, even on my side. I notice with most IEMs I tend to get some cutoff on whichever side/ear I happen to be laying on; the venting on the SA6 seems to help.
Should also add that my other IEM-of-the-moment (yeah, I have too many) is the EE Hero. Compared to the SA6 it can sound bright at times. It’s a testament to the all-BA SA6 that it can sound more organic than the Hero with its hybrid setup.
phthora
Thanks for the info! I contacted them 3 days ago, and they told me they'd ship it right away. But, the status hasn't changed from 'order confirmed.' I will give it some more time, but it's going to be hard waiting for these earphones!I ordered the same day as you. I received initial tracking info on the 17th. From there it took only 3 days to leave their warehouse in mainland China to HK to clearing customs/NY & I received it on the 20th. Have you reached out to Linsoul? They were pretty responsive when I emailed them about the faceplates.
