Hapster
- Oct 27, 2011
Oh, you shouldn't be advertising on other threads. But dang, that's a snag.
So,after posting my 2Kj's up for sale,and trying to deal with some head-fiers ,who have credit card problems.
I pulled the ad,and have begun re-testing them,with new tips.
Finally making good progress,I have put on 130 hours,and things are beginning to open up,much better sound separation,highs are higher,crispy,mids are forward,female vocals come through extremely well,bass seems to be slightly reduced in comparison to the Titan's,but still definitely there.
Although,I am not an expert on sound quality,and IEM's,I would recommend,anyone thinking of getting theses,just do it,they are a great earphone.
Just be prepared to put in 100-150 hours of break-in,and choose your tips ,carefully.
Thanks to all ,who gave me a helping hand..you guys are the best!!
Mike
Son, Balanced Armarture drivers (1 for mids and 1 for highs) don't change that much, if at all. It's you getting used to the sound sig.
Shh, let him believe whatever he wants.
yeah,whatever it is..you might be right.
All I know,is I like-em..could be the tip change, too.?
Tnx-Father..
That's a lot more likely, there's hella spacers, tips, and other stuff that can all have an effect.
I for one am loving the dn-2kj straight out of the box, and that's coming from the Fx-1100.
Just had to make a few minor Eq changes. Brought up 10-20khz by 1-2.5dB and 20-60hz by 1.5db-0.5db.
Only 3 complaints:
1) Wide Nozzle, I have such small ears, and the stock comply tips are med size, I can hardly fit them in.![]()
2) Such low impedance, when used with my V-moda Vamp verza, the noise floor is much louder than with the Fx1100 or the T-Peos H-300. Not sure if that's going to effect SQ since there's essentially always a buzz going on in the background.
3) Non removal cable. Every time the cable gets caught on something, I'm going to die a little inside.
Other than that, I'm pretty happy so far.
just returned my IE-80's to Amazon and ordered the Dunu DN-2000j's for $330 bucks, only $40 more than the senns cause they had tax on them, the dunu's did not. very excited to try these out on Monday.
Well, you can be sure of one thing; it's not going to leave you indifferent!
