This is J model, which means for JAPANESE market originally. Even though more work has been done than plained you should be expected to have a very-very bright IEM because all asian market targeted IEMs are bright. Name me one dark sounding IEM from Asia, I can remember only XBA-Z5 from Sony which has a very bad reviews in Japan because of lacking treble and absense of brightness. European and Asian hear things differentely, that's the biology and you can't avoid that.
I personally love bright, clear and crisp treble, probably more than others' usual preference (also love tight smooth bass which DN2000j is doing perfectly)
I am also in Asia which I dont know if that is an coincidence as you mentioned. LOL. To be frank after been listening for several weeks, I also found some tracks to
be on the high limit and start to feel sibilant, even on some male vocal. I am not saying I dont like it but just that it starts to become a bit irritating many points in
the track. So I started to play around with tips and rings as supplied in the package.
I found that clear white silicone tip would result in the brightest sound while the gray tip with sponge embedded inside would sound a bit less bright/sibilant.
Moreover, the further away the opening end of the tip is from the mesh where the sound is coming out, the slightly less bright/sibilant the sound will be.
Therefore, I end up using the red ring with the gray tip with sponge inside (+ the base ring) since I feel that the red ring push the tip most away from the mesh.
Many of you may find the color ring is up for other purpose. I am not sure about it. I did write to Dunu asking how to properly use the color rings and what
their designated result are. The answer from Dunu was that these rings are for improving the fitting to your ears which I totally understand why some say the color
rings improve bass since without a proper fit to the ear canal, a significant amount of bass would be loss.
I also notice that the material of the tip affect treble considerably. All the Comply tips, being memory foam (material surface somehow like fine sponge), would absorb
most of the harsh sibilant treble to the level that I find the sound losing clarity and crispness, so I dont use Comply tips at all. However, Comply tips might be just right
for many other people, especially the round one, Ts-500 comfort series. I feel that the T-500 isolation series does absorb more bright sibilance (as the distance between
the opening of the tip and the mesh is more) and the Tx-500 absorbing most with the wax guard making the overall sound quite warm.
I love the bass ring but cant avoid driver flex every single time I put them on because I need to push the DN2000j quite hard in to my ear to get a proper fit otherwise
I wont get that bass quality. So lately I remove the bass ring being worried about the damage to the driver. Anybody got any solution for this? I dont think I can get the
same effect by adjusting EQ.
Well all are just my opinion, YMMV.
Happy listening.
