Oh this is bad
such a good looking and maybe souding iem but it has so much issues with left or right driver. I don't want to pay $200 for these and after 3 weeks I will end up sending them back to repair. Are there any good alternatives for dunu dn-1000?
$200 is through their own site, On Amazon they are priced at ~$150+ (LMUE - Lend me ur ears sells them at 158USD on Amazon). I also feel so left out, With
Joker being inactive on both Head-Fi and
his site & head-fi's massive redesign.
I cannot find a replacement IEM that beats this beast.
So far these are the only IEMs that crossed my mind in search of a replacement or upgrade...
Multitple / Hybrid driver -
DN2000 is a sidegrade (Loses the Bass impact of these, Fun for Clarity/Flat not worth $100 or even upgrade from this set imho).
Dunu 2KJ is entirely different tuned not even close to this, it caters to analytical lovers. Better to disregard this as you won't have any fun with this purchase.
FLC 8S is expensive but the sonic performance is great, thanks to extreme tuning (Bass is great but not at DN1K class, but perhaps a touch different at it's closer to the DN2K). It has the port pin size issues some reported that the pin size from the stock cable is .74mm or some, while the aftermarket ones are .75 and using them makes the port useless with the stock cables as it enlarges the port for the removable cable advantage.
EarSonics Velvet which seems to be an upgrade but very out of the class at 700 Euros, v2 is out seems like it has addressed a few issues with the knob check it on THL site (Joker's site).
Single driver
RHA MA750 can't beat these at all as the DN1K has more Bass Quantity / Quality and supreme clarity due to Hybrid setup (These are great purchase for their sound, no questioning their sound for their price and 3Yr warranty, Everyone likes their build but I found their cable rubber being prone to get rubbed often at the 3.5mm spring which helps to maintain the integrity, Mesh isn't that great it's weak and not like DN1K),
VSonic GR07/Bass Edition lacks bass quality and quantity despite the name but it does shine at others, it has superb sound that's no doubt, You can hear almost every instrument and note, thanks to that Bio Cellulose driver it has. I loved their sound, the build quality is questionable though there's a new version that's having removable port but it has lost the high number of tips selection that original had & the new cable is also good I guess.. I bought the original GR07Bass Edition which I returned later,
Dunu Titan 1 sound is very different and cannot match to this Hybrid Driver set BUT it's definitely a great IEM perhaps rivals the RHA MA750.
Sennheiser IE80 these cannot compete with the DN1K at all or the GR07BE due to the veil they have, too much of mid get clouded due to Bass but the soundstage is vast, I returned them because they felt inferior to the VSonics in tonal clarity and perhaps burn-in changes them overtime, There's an upgraded version IE80S claiming to have solved that veil, idk..I don't think an Single Driver set can beat these.
Edit : Perhaps the
RHA T20 is also a good contender as it bests the MA750, but not like it can beat the DN2000 in bass at Sub-Bass levels, though it mid bass might be good..That's where the DN1K's shine, the sub bass goes so deep and you'll love how it does with maintaining all the superb clarity with it, ofc red spacers.
I personally suggest you to buy Dunu 1000 from LMUE from Amazon and give them a spin because you'll love these IEMs only downside is it's a little bit congested, very little... Also If they get damaged, you can ship to china they will repair them for free in under warranty and then keep them safe. They really performed well without any issues, Just be careful of the wax don't let it clog through the mesh, Buy Comply T500's if needed.
Also check
THL site's jokers list you may find some good alternatives, check out comments too, he posted a recent review & few comments until 2017 March but not anything later, He seems to be busy but still runs the site and the FB page of THL, I found his review and sound taste very appropriate and matching to my taste as well.
