Douk Audio U2 Pro DDC - Poorman DDC for an affordable & clean digital signal
Jan 6, 2022 at 1:13 PM Post #244 of 614
Yes. I had the 5V power supply on to the U2P. Please share a link to your lightning camera cable if the iPad connection works on your side.
Sorry, just got a chance to test this a few minutes ago, everything works fine.
iPad>Camera Adapter>USB Douk... iPad poweredby adapter, Douk powered by 5V cable
Cam adapter Link...
ref=ppx_yo_dt_b_search_asin_title
Cheers!!
Jan 6, 2022 at 1:28 PM Post #245 of 614
Cam adapter Link...
Cheers!!
Greatly appreciated. I've just ordered the same USB 3 adapter and hope to get the same good result.
Jan 6, 2022 at 1:31 PM Post #246 of 614
Fingers crossed for ya!! You're welcome!
Cheers!!
Jan 6, 2022 at 5:16 PM Post #247 of 614
Received my 3pcs TXCO version. First impressions verses the regular douk u2 pro are find a slight quality increase, not as shouty and gets some of those fast cymbals right where it kind of sounds like there's an unnatural break when it gets super fast. maybe 3-5% better across the board with maybe better dynamic range.
Jan 10, 2022 at 5:31 PM Post #249 of 614
Cam adapter Link...
Cheers!!
I got the same lightning to USB 3.0 adapter you posted but the U2P still does not work with this adapter. All my USB cables are USB 2.0. So is the stock USB cable coming with the U2P.
If possible, could you help testing whether USB 3.0 vs 2.0 cable matters? I am using coax connection between the U2P and my Airist R2R DAC and am not sure if there is a compatibility issue there. Thanks.
Jan 10, 2022 at 5:38 PM Post #250 of 614
When I use my adapter in Roon I choose listen on this device, can't remeber what your using, sorry!
I don't believe I own any 3.0 cables besides the one for my iFi Zen DAC
Jan 11, 2022 at 5:46 AM Post #252 of 614
@TomNC. It only matters whether U2Pro is powered from the external power adapter or draws a power from USB bus. The later doesn't work with Apple devices.
You can use 2.0 cables, U2Pro only works in 2.0 mode.
Jan 11, 2022 at 1:01 PM Post #254 of 614
Thanks for your input. I had the U2P powered by a 5V USB source and the blue LED was on.
I just tried Apple music using my adapter to the U2. At first it did not work, sound was coming out of my iPad.
I then reconnected it and Sound started following to my DAC.
I then noticed that one of two tapas down on the iPad volume level and nothing was audible, Soo double check your volume control on the iPad, and try connecting it after something is playing.
As you can see in the pic just basic generic cable, sounds very good!
Hope that helps,
Cheers!!
Jan 12, 2022 at 1:38 PM Post #255 of 614
Older design for sale during last 4 years. The #2 and #3 are the same Leaf Audio design v1.2.
The latest one v1.3.1 has LVDS (HDMI). Your links looks line that:
I came across this today - Leaf Audio CMD-17 - w/ the options of upgraded clocks - valid alternative to the Douk since the upgraded versions are sold out?
Edit - cheaper link:
https://www.aliexpress.com/item/1005003276907662.html
