Indeed, my experience with the U2 pro (Crystek CCHD-957 Oscillators) also improves the sonic presentation in terms of clarity and transparency.Got the U2 with 3xTCXO upgrade, fantastic ! Presentation is like 'glass' is only way I can describe it vs USB...not very
scientific, I know.
Any of you find the optical connection can cut out if you move it ?
My Hugo 2 port end does not have that issues...
Just trying to find out if others are a bit loose on the U2 port. I know you won't normally move them around
but I set it up at different locations and when moving it a bit more can cut out a few seconds..not the optical
cable, tried 2 already.
Am going to also get a coax cable and test out vs optical - see if its even possible to tell the difference.
I doubt you can tell the difference between this DDC and ones 5x 10x etc...in blind tests.
My ears/brain could not detect significant difference between coax spdif and optical. However I am keen to know about your finding as well as it could be component dependent (was using basic spdif coaxial & optical cables).
I do not have the chance to experiment anymore as I have returned this nice and affordable little DDC because it does not pair quite well with my DAC (too much jitters causing locking issues)
