sssboa
- Dec 26, 2011
Might I suggest you try upgrading the fuse in the Yamaha. I upgraded the fuses in my concept 16.5 and I found that the soundstage of my 16.5 improved considerably . I suggest you try a isoclean fuse which is the fuse I used for my concept receiver. Actually the fuse improves everything and not just the soundstage. The change upgrading fuses can be similar to what you get from a power cord upgrade but of course it is much cheaper than a lot of the high end power cords.
Hi
Thx for this. I am skeptical though. I have a real problem now with power. When I power on my PC into the same power grid in the room I get high pitched modulated electrical noise in all audio equipment connected nearby, it's like hearing hdd working in all speakers and headphones. The problem disappears if I connect the PC to a battery (except for equipment that is somehow still connected to PC by audio cables), so the noise must go somehow through the power grid from my PC. Now will the most expensive power cable condition the electrical power to eliminate this noise? We both know the answer is no. Why would I believe then that it "conditions" the normal non-problematic power to make equipment sound better? I don't believe in cables affecting sound quality unless they are shoddy cables. Why is it always with audio? Why won't I get a better picture on my tv using such a cable and fuse? Why only cables? There is air between our ears and speakers, why not condition it with special gas like helium or something to make the sound waves more audiophile? If I posted an ad on a forum that I sell such a gas in compressed bottles, do you think I would get queries about the price? I guess I would. Hearing is illusive, I bet sometimes someone calls you and you recognize them by their voice as someone else, does it happen to you that someone visits you and you think they are someone else by looking at them? But I started entire different topic.
BTW You seem to know about monster receivers. Do you have an opinion about Hitachi late 1970s series sr-903/sr-904, sr-2004, they are G class.
Best Regards
Andy
