Prototype.Prodigy
It’s the Q5 Amp / Dac that will work perfectly out the box with Android phones. Sorry for the mixup.
http://m.fiio.net/en/products/83
The Fiio Q1mk2 has a max output of ≥11 mW(300Ω / THD+N<1%) so it should work ok yes.
Sorry for asking so many questions etc I'm very new to the audio scene.
by 'should work ok' do you mean that it will sound better then the 80ohms version? (keep in mind I do like my bass in headphones)
Don’t worry about asking too many questions you are trying to find the best fit for you with your hard earned money not a problem.
While I have not heard the Q1 but have heard the DT770 250 ohms but that was on a desktop amp . Just by specs it will run them but probably not real well.
This is not always true. Sensitivity has as much or more on ability to drive. Have a pair of 46 ohm headphones that I bet the Q1 could not get much over normal conversation volume if that. They are 85 dB/mW in sensitivety and planar magnetic so it would not run them with ease.The lower the ohm resistance the easier the audio device is driven by an output device.
Given that the Fiio mk2 is rated as 300 means that it can drive anything up to 300 with ease.
Any device beyond that it might struggle to power. I mean it will work to a degree but it will sound a bit muted and underpowered.
And you are welcome for the help. That’s what a forum is for.
Well your amount of bass and mine could be different as I’m not a big basshead but do like me some bass. The DT770 do have a good amount of bass . The lower impedance versions will probably be better fit for you .Alright, So the FiiO Q1ii (2nd Gen) can run the 250ohms but it will not sound as good as the 80ohms version becuase it cant drive it fully. So I guess I should go for the 80omhs version instead just to be safe.
Also, do the dt770 pro's have a good amount of bass? I would test them in a shop but high spec headphones are usually not in stores for testing in the uk. besides beats of course.
Alright, so the dt770pro 80ohm with the Fiio Q1 MK II will be perfect?Well your amount of bass and mine could be different as I’m not a big basshead but do like me some bass. The DT770 do have a good amount of bass . The lower impedance versions will probably be better fit for you .
Alright perfect. Cheers mate.The Fiio mk2 is a Amp & Dac and interfaces with your pc via USB. so that will not be an issue.
Use the high gain setting with your dt770pro and you will have plenty of volume I assure you.
If it ends up being too loud then switch back down to low gain.
Thanks for the help I really do appreciate it!Well since @Prototype.Prodigy has the Q1MKii and DT770 Pro’s I’ll let them guide you from here as I don’t have both so can’t say but since they do I’ll just stop here .
One last question though. What would be the difference between the FiiO Q1ii (2nd Gen) and the Fiio E 17 for K. They are the same price so I was just wondering which one was better. Thanks!Well since @Prototype.Prodigy has the Q1MKii and DT770 Pro’s I’ll let them guide you from here as I don’t have both so can’t say but since they do I’ll just stop here .
Not all DAC/AMPs have gain toggles, and most don't have a bass boost.To clarify some important details.
Headphone (Amp / Dacs) have more benefit than merely volume increase. They also add additional functions such as hardware based toggles for Gain (Input Voltage) and Bass Boost.
This allows you to drive Headphones / IEMs and In Ears with greater efficiency and clarity, which is important for higher fidelity listening devices.
In addition you will have 2 primary outputs:
3.5mm unbalanced Audio jack for standard unbalanced driver based audio devices.
2.5mm balanced Audio jack for balanced driver based devices. Which is arguably the much better and purer sounding option if available.
So in any case a quality Amp / Dac will be a worthy investment I think.
Based on what i've read apparently amps help a hell of a lot on mobiles. When I use my current astro a40tr's on my iphone x, they have no bass at all and sound incredibly weak.
Alright, thanks!
Do you think I could power the 250ohm version or would that be pushing it?
