Dec 24, 2014 at 10:24 AM Post #376 of 678
I liked Mr Trev's theme too. I likes the bright white theme best as it was so easy to read. The X3 just look so much nicer when the screen was really bright. I also liked the white background fro when the battery was charging when it was off. I am hoping that a similar theme can be made for FW3.3 sometime :-)
I still would be using that theme from 3.0 if it wasn't for the sound quality being a little bit better in 3.22b.
Dec 24, 2014 at 12:45 PM Post #377 of 678
Just got the new fw, I'll try to have the themes updated this year
Dec 25, 2014 at 3:51 PM Post #386 of 678
I have a ? for anyone here ..
I wanted to change the color of the "battery charging" png's .. to match my theme color from the default green.
However .. when I change them in Paint .. the battery charging does not display properly. It shows the 0-5 bars then goes to another view and then returns to the battery display.
The default firmware files work fine.
I have not had any problems changing any of the other files at all. They all worked fine with my new color.
Also ... is there a way to slow down the boot time ? I would like it to be slower .. to view my boot images a bit longer.
Dec 25, 2014 at 6:00 PM Post #387 of 678
What other view does it switch too?
Assuming you still have all 7 pngs, the first thing I'd check is make sure none of the sizes/formats got changed from 43x80 png. Other than that I'm not sure what else could be the problem.
Don't think you can slow the boot animations down, but I do think I've read if you change all the gfx to blank it can boot faster.
Dec 25, 2014 at 6:56 PM Post #388 of 678
Hmm .. well I went in and numbered them to see what was happening .. and well egg on my face. It is working fine now. I checked and all the file sizes are the same as I would expect.
So .. it is working.
Dec 27, 2014 at 8:48 PM Post #389 of 678
Here is my theme ...  it is basic but I think it gets the job done. It is for Firmware version 3.3
The themes that I changed are 2 and 5 .. the rest are the default. Let me know .. if you think there can be improvements.
https://drive.google.com/file/d/0Bwp7efYuPlB2VTRyYXpnOEhyMDg/view?usp=sharing
Just click on Download at the top.  It is Google Drive .. a bit different than some people are using here.
Dec 27, 2014 at 10:12 PM Post #390 of 678
Good stuff, making a new theme :)
If you haven't fixed your issue with including slower graphics, just make multiple images the same. I.E, if you had 12 boot .pngs, make 1,2,3 the same image.
