Yes, as Panda said the most important thing is to solder both sides in the same order. If the sides don't match accidentally, the sound will be out of phase - it will sound very unfocused and weird. I use this test very often after soldering because it shows me the channels and the phase as well.Hi,
I'm new to this and on the driver there are two pole, do I need to solder the 2 wires (ground and signal) in any particular order ?
Thanks for helping.
