Anybody tried these "15.4mm" drivers yet ? if yes any hint about the sound? I'm curious
@HungryPanda maybe?
@HungryPanda maybe?
@HungryPanda maybe?
Maybe they did a special PK plastic covers-like to be adapted to 15.4mm ? not sure what to trust so yeah for now it's safe to think it's 14.8.it's driver cover looks like 14.8mm rather than 15.4mm.. also some has orange point while some has purple, if it makes any sense..
Sometimes you need to add some tin (almost a very little ball) at the end of the solder tip to help unsoldering wires from drivers, at 300°C it should do the trick(the solder was quite hard to heat up for some reason and I was very frustrated with the whole thing when I tried this haha)
yes of course, but what was very strange and disappointing to me that the B40 channels had very significant differences, and very similar across multiple units, as if the left and right drivers were from completely different batches or something. My other cheap earbuds have much better matching, the best of all is my Qian69 which has virtually the exact same response in both channels according to my measurements.Drivers do have to be matched. Even expensive brands take great care about it.
Yep, thanks for the tip It had some coating or different material I think because the smell was very different too.Sometimes you need to add some tin (almost a very little ball) at the end of the solder tip to help unsoldering wires from drivers, at 300°C it should do the trick
I don't own 600 but from what I think/readed the 600 looks to have slightly more bass (& more sub-bass especially?), but overall presentation/sound should be the same. All depends of course of the driving power to match the same.Can anyone say how are the 130ohm beryllium vs 600ohm beryllium?
Thanks. Ordered them couple days back, couldn't find any info except one post on here that said they are totl level, guess I will have to order the 600ohm later, coming for samsara, going to miss the sub bass...I don't own 600 but from what I think/readed the 600 looks to have slightly more bass (& more sub-bass especially?), but overall presentation/sound should be the same. All depends of course of the driving power to match the same.
600 ohm is very difficult to power in quality. That's why I generally prefer to stuck max at 150/300 ohm.
