Into The Light5
Good afternoon lads. i hope ure all doing well.
Finally, the cable arrived, here is the physical comparasion of mogami 2893 and 2799
based on the web spec sheet, they share the same 4 core internals, the difference is 2799 made to be an internal cable while 2893 for external cable.
Now waiting for the 32 ohm blue DLC + LCP driver
Outer Diameter :
mogami 2893 4.8mm
mogami 2799 3.2mm
canare L4E5-AT 5mm
All three internal is 4 core, so it can be used for balance termination
Outer Diameter :
mogami 2893 4.8mm
mogami 2799 3.2mm
canare L4E5-AT 5mm
