Look who I've just found into my mailbox. Lucky me I buy them 13€ into a Swiss internet store. This was the last one.
DIY Earbuds
- Thread starter gwompki
Be careful when you're detaching that silver part on the shell. Also use silver plated or pure silver cable with them
Thank you for your help.Be careful when you're detaching that silver part on the shell. Also use silver plated or pure silver cable with them
I already have one pair of red film 150Ohm with a silver plated cable into pk shells. I have a pair of metal shells for them, do you think that I could have good results with this setup?
rprodrigues
@PapyKahan
Which model is that? Nokia HDD-1?
Yes exactly
My first mod is this metal shell which is great, fit and comfort wise, but this driver give the best result in docomo shell.Thank you for your help.
TheLastAurora
Hey, guys! So, am I missing something? Not getting sound. I'm new to this hobbie, so...
Did you try to measure the resistance ?Hey, guys! So, am I missing something? Not getting sound. I'm new to this hobbie, so...
If you have 0Ohm the voice coil wire may be broken.
If not you have a wiring problem.
vygas
Congrats my friend, you got the better batch of the HDD-1 drivers. I've had a couple green dot Red Films that are presumably from newer HDD-1's and they didn't handle the low-end as well as the black marked drivers. Still, be careful when opening that shell up for a re-cable, I've had to snip the rubber ends of the stress relief at times just to fit some.
TheLastAurora
Don't have a multimeter. But i checked both the solder and the wiring and it's everything ok. It might be broken then...Did you try to measure the resistance ?
assassin10000
Ordered a pair of Nokia buds off ebay. Hoping they're the same drivers as the PK2 (or was it BK?).
rprodrigues
@assassin10000
Could you tell me if these are the 14.8mm 32ohm ti drivers you have, please?
https://www.aliexpress.com/item/1005001686050644.html
assassin10000
@assassin10000
Yep.
Also available here:
https://a.aliexpress.com/_mLVj0Bt
https://m.aliexpress.com/item/1005002318950933.html
assassin10000
Doing some prep, as I'm still undecided on what drivers I want to use for my now donor K's shells.
I also took some time to figure out how to take apart a pair of 14.8mm 150Ω redfilm drivers (that had a one bad driver). They don't fit the newer style covers very well, too loose. If I decide to use my last good pair with the K's shells, I'll most likely have to glue them.
The older style covers do not fit the K's bell shaped shells.
Recable done
Now let's go to my burnin process
Total: 19 (members: 0, guests: 19)
