DIY Earbuds
- Thread starter gwompki
I see that. You use very nice parts and I've noticed that you pay a lot of attention to cables.some of the pics ill post and already posted here are my past works.
I am into DIY / making custom earbuds.
here is a white docomo w/ silver back shell cover which i mod last year.
cable is litz spc w/ connoisseur gold plug.
I assume you procure these parts locally?
I like Docomo shells. Foer me personaly this is one of the most comfortable shells
and and I am very pleased with how PK1 "red film" and PK2 driver sound in them.
This is my PK1 150ohm "redfilm" with Furukawa cable
irv003
Member of the Trade: Newbsound/BBB/Bisoy Buds
actually cable is part of what i want them to sound. its not really that i like premium stuffs. its just that docomo stock sound is warm to dark, installed spc to make them less warmer.I see that. You use very nice parts and I've noticed that you pay a lot of attention to cables.
here is TY Hi-z 32 ohms version 2.
modded it with black OFC wire w/ ranko plugs.
basic build, better sound
Ranko plugs are really good. They require silicon "tail" because large opening on the back.Once I bought few copy of Ranko pluugs and half of hem broke. The isolation on pinouts was badactually cable is part of what i want them to sound. its not really that i like premium stuffs. its just that docomo stock sound is warm to dark, installed spc to make them less warmer.
irv003
yup theyre one of the most copied plugs in chifi. theyre good but also expensive compare to other brandsRanko plugs are really good. They require silicon "tail" because large opening on the back.Once I bought few copy of Ranko pluugs and half of hem broke. The isolation on pinouts was bad
Yarbo plugs are also good. GY-35GS-L is really massive. Only 3.5mm. It will be nice to see Pentaconn in this form
Also like this no-name twins (red & blue)
irv003
Yarbo looks ultra cheap
It's cheaper than Ranko but is not bad quality, also looks more attractive than RankoYarbo looks ultra cheap
irv003
looks interesting.It's cheaper than Ranko but is not bad quality, also looks more attractive than Ranko
where is it can be found? aliexpress?
Golden plug is gone from Ali, I cn't find the link.
This is the blsck https://nl.aliexpress.com/item/32236808365.html
irv003
irv003
I got a lot of RCA. Yongsheng.
It is a subsidiary of Neutrick. The connectors were of decent quality. There are also jacks of this company.
https://nl.aliexpress.com/item/4000...earchweb0_0,searchweb201602_,searchweb201603_
earfanatic
- Oct 31, 2007
Hello,
I have an Auglamour RX-1, I am looking for Your suggestions how to tune it.
This is a zinc alloy earbud. Two vents (2x2 small drills) are on the bottom around 5 and 7'o clock position.
I have opened it because one vent seemed to be blocked on one side, and found the cable insulation broken too.
I will either recable it or cut the cable sorter for quick repair.
As You can see the front is badly covered with glue, and the driver air holes are covered with a sticky, horseshoe shaped foil, which looks like silicon to me.
It definitely needs a cleanup.
I think this is a good earbud for further tuning, spacious shell, which I find attractive and comfortable.
The front pops back fairly well to the shell, allowing changes without glue.
What is your impression? What can I try? (I have no measuring equipment but my ears).
