DIY Cable Questions and Comments Thread
Jan 15, 2014 at 7:43 AM Post #1,141 of 10,590
I would just use super glue. That bond should never break, and it wont expand a noticeable amount. And you can keep that sweet wooden splitter. Easy, cheap, effective; super glue.
EDIT: Don't use a lot though, if it oozes out of the edges of the connector it could get pretty ugly.
Jan 15, 2014 at 7:49 AM Post #1,142 of 10,590
My wory is that the cable falls out again and I cannot open up the case since I glued it too well... Have to make sure the cables sit tight forever in the case..
BTW - the case is gorgeous, but the angles are wrong - to much of a split to the Y.
Jan 15, 2014 at 2:04 PM Post #1,148 of 10,590
What is the best 4 pin xlr connector and the best cable for making my own cables? I am gonna go balanced with my hd650 and my incoming LCD-3 :)
Jan 15, 2014 at 3:52 PM Post #1,150 of 10,590
Cheers :)
Jan 15, 2014 at 5:48 PM Post #1,151 of 10,590
As for 4 pin xlr's only neutrik makes one worth considering in my opinion so you don't have many options.  As for cables that is a very good question.   What kind of cable are you looking for?  Copper, silver, SPC?  Or how much do you want to spend per ft?
Jan 15, 2014 at 6:02 PM Post #1,152 of 10,590
  Video, hope it's clear enough.
First of all, thank you so much for making this video!  Definitely helped clear up a lot of question I had!
Second of all is another question.  Would you have to wrap it?  It looked like it stuck together very nicely at the end of the video there, even without any heatshrink or anything
Jan 15, 2014 at 6:03 PM Post #1,153 of 10,590
Well I dont know what difference the different types of cables do. I want the best possible and dont know what I should get.
Also a nice place where I could order from would be nice to know :)
Jan 15, 2014 at 6:04 PM Post #1,154 of 10,590
I'm kind of in the same boat as you, and have been looking at BTG audio and Double Helix Cables.  DHC is a bit more expensive, though
Jan 15, 2014 at 6:06 PM Post #1,155 of 10,590
You don't have to shrink wrap it, it holds as is when twisted as indicated.
Have made a few IEM cables and they dont come untwisted either
