DIY Cable Questions and Comments Thread
Oct 4, 2024 at 11:55 AM Post #10,561 of 10,576
One of these days she will have to be finally retired for a Hakko but a little tap every now and then keeps her going.
I love the use of pipe fittings in the rack.
Oct 4, 2024 at 12:02 PM Post #10,562 of 10,576
I added patina to the copper supports and can swap them out when I change gear if need be. All racks are solid cherry. I also built these shelves for a buddy in California. IMG_8002.jpegIMG_7890.jpeg
Then one of my mini racks in use.
Oct 4, 2024 at 12:43 PM Post #10,563 of 10,576
One of my headphone stands. I built the cables of course and use mini four pin XLR’s so I can swap between 3.5mm, quarter inch, and standard four pin XLR’s.
Oct 4, 2024 at 2:21 PM Post #10,564 of 10,576
Awesome work. Unfortunately I don't have the patience for woodworking but can really appreciate those that do.
Oct 4, 2024 at 2:43 PM Post #10,565 of 10,576
I started doing woodworking because I wanted to build all I could of the amps I designed.IMG_8217.jpegIMG_7251.jpegIMG_7297.jpegIMG_6521.jpegIMG_6103.jpeg
More audio related work. I have built cables for most every brand of circum and supraaural headphones. Not so much with IEMs.
Oct 12, 2024 at 7:08 AM Post #10,566 of 10,576
The 4.4 situation really drives me crazy. It seems like it's basically original Pentaconn or near junk. I haven't tried the Eidolic plugs though. I think the main issue is the plastic, which I wish someone would make the plugs with teflon, like you can get with some regular 6.3mm TRS plugs.
Though it's tedious, I did manage to solder even the cheaper 4.4mm plugs by cutting the wires to exactly the right length to solder to each point, then lining everything up with helping hands, tinning contacts beforehand etc.
Hey bud.
Solder the tip first, so the smallest contact. Easiest one. Then wrap that joint and all its metal in some plumbers tape (Teflon tape). Cut along its length to narrow it, then give it a good 2 or 3 winds.
Now you can solder the next in line without fear of bridging. Wrap it again and keep going. Multimeter test and give it all a light tug, if passes then give it all a good tight wrap or hotglue her up
Nov 14, 2024 at 12:31 PM Post #10,567 of 10,576
Wondering if there is a Headfier in the USA that can reterminate a Lavricables Grand?
Nov 14, 2024 at 5:02 PM Post #10,568 of 10,576
Hey bud.
I just wanted to come back and thank you for those tips. That teflon tape hack made the job much easier! I don't typically fill my connectors with hot glue, but going forward I will. Re-using them was my reason, but they're cheap enough to just use a new one when needed.
Mar 2, 2025 at 10:44 AM Post #10,572 of 10,576
Anyone got some recommendations for some mid-priced copper wire? Looking to make a thick cable, either 4 or 8 strand and want bright shiny copper. not looking to spend $30 a foot but I'm also not looking for Home Depot lamp cord. It's hard to wade through the myriad of Aliexpress sellers trying to figure out what's legit and not.
Mar 2, 2025 at 12:55 PM Post #10,574 of 10,576
Mar 3, 2025 at 11:02 AM Post #10,575 of 10,576
https://www.aliexpress.com/item/1005006099635537.html?pdp_npi=4@dis!GBP!£6.00!£6.00!!!53.51!53.51!@211b816617410176565486496e23a3!12000035737671022!sh!UK!1635865585!X&spm=a2g0o.store_pc_allItems_or_groupList.new_all_items_2007616048764.1005006099635537
I wouldn't go any fatter than 1.5mm per wire for an 8 wire cable or you'll have trouble getting it in the connectors
