damascato
Member of the Trade: Marco Custom Cables
- Dec 3, 2011
Heat shrink them from the outside. It’s the only way to secure them properly.
Need them to connect ground to both files then?You should be able to get ground from the 4.4mm sleeve, unless it's not connected. In some cases you need to get ground from a 3.5mm socket.
Not really. The end screw cap gives adequate secure tight fit if enough internal heatshrink is used.Heat shrink them from the outside. It’s the only way to secure them properly.
Very nice! I worked in medical equipment repair for 33 years and replacing Lemo connectors was a very laborious task. Great connectors, but agreed, as difficult as the HD800 ones to get a clean, stable connection.First time hooking up some LEMO connectors for a client's Focal Utopia.
Usually used in the medical industry they're probably about as tricky as Sennheiser HD800 to terminate and make secure.
Came out good but I feel like the older I get the shakier my hands get, lol.
Happy client.
I would try using the 4.4mm sleeve. Ideally you want ground to be connected on both ends and on both channels. If the device you are using doesn't have the 4.4mm sleeve connected to ground (some DAPs are like that), you need to get ground from somewhere else, usually people get ground from a 3.5mm socket given that it should be grounded.Need them to connect ground to both files then?
Problem with 4.4mm is that often the don’t have sleeve internally…
why does it need to be thin? HifiMan doesn't have recessed plugs...Hello,
I'm looking for a quality 3.5 trs connector for a hifiman. It needs to be slim like the pic.
I found a couple on ebay but they look cheap. Thank you!
edit: I found these, but not sure they will fit?: https://www.redco.com/Redco-Male-3.5MM-Mini-TRS-Solder-Connector-Low-Profile.html
https://www.parts-express.com/connectors-adapters/audio-connectors/35-mm-mini-connectors/gender/Male
oh really? I don't have them yet, and read that some cables don't fit. I think some have a recessed, manufacture issue. Prob ok...Thank youwhy does it need to be thin? HifiMan doesn't have recessed plugs...
No worriesoh really? I don't have them yet, and read that some cables don't fit. I think some have a recessed, manufacture issue. Prob ok...Thank you
Hart cables are pretty popular(for a good reason too). I keep missing them on 2nd hand market at great prices. I ordered some connectors from Ali and decided to "mimic" hart cables. If you can bare the wait, Ali has pretty good selection and prices. Plus you will have your own diy custom cables perhaps cheaper.Thank you. Getting frustrated because I ordered cables at a place and wasn't happy with the shipping. I just bought it and tried to forget it. Now I'm back there looking at connectors with $10 shipping. I was trying to save money, but as usual I am losing. THEN later I read about hart cables after digging digging digging for a reasonable custom cable. Now I can't avoid hearing about them or being recommended. Sorry, frustrated. I might just order the stupid thing after all and have the parts for an extra.
