Hey y'all,
I am getting ready to start making my own cables and I want to start with a cable for my M1060s. I have a Periapt cable, however really dislike how long the 2.5mm plugs are because they extended for recessed jacks, and can poke at my shoulders if I tilt my head too much either way. I have only been able to find these plugs on Redco, however wanted to see if there are any options for 2.5mm that do no have the extension?
https://www.redco.com/Switchcraft-850.html
Also, I want to use the pig-tail system where the cables are connected by a mini-xlr connector, I understand how they are wired for balanced termination (in concept), however can a 4-pin mini xlr connector be used for SE cables as well, or will I need to use 3-pin mini xlr connectors for those cables? I'd like to keep the same connector for my balanced and SE amps so if the 4-pin can work with either that would be great.
Thanks in advance for the help!
