DIY Cable Questions and Comments Thread
wolfetan44
- Mar 27, 2012
Extremely hard to put wire into.
ben_r_
Youve tried the teflon tape around the end trick? Tons of people do it and some do it quite often. Maybe you just havent learned the right trick?
liquidzoo
- Apr 9, 2012
Also depends on the gauge of the wire you're attempting to put in. I've found that Mogami 2534 is much harder to thread into Type I Paracord than Mogami 2893 is.
- Mar 4, 2013
The trick I have found with paracord is trying to make the ends of the wire as smooth as possible. What makes it a pain is the wires catching on the material as you try to thread it through. So making a cone with the tape and taping all the wires at once works. Bending the wires over helps. Taping them to something a bit more smooth and pushing that through works (like a paper clip). If the wire is bare, you have more than about 2 strands and you try to push it through you are going to have a bad time. Techflex is easy you just push the wire through no problems. Also I like the look of it more than paracord sometimes too.
stothy
- Aug 15, 2013
Hey guys, I am completely new to DIY cables but I want to make a replacement for my AKG K450s as I don't want to pay extortionate amounts on ebay etc for a cheap thing that will break after 2 uses.
Could anyone point me in the direction of a guide and tell me what parts I need?
If I wanted to add inline controls/mic what would I need to do?
Thanks in advance!
Thanks in advance!
wolfetan44
- Mar 27, 2012
I didn't try the tape at the end.
- Jan 21, 2013
Even a little electrical tape. A LITTLE, stretched and pulled one and a half times around the tip provides a nice thin,slick coating for the tip of the cables to get through pretty easy. Then you just have to do the push/pull worm trick.
Once you get it down you can just stick back and watch some TV or listen to some music and worm away until you're done.
glunteer
- Sep 15, 2012
What size of paracord to use the 22 AWG (Canare L-4E5AT) ?
kwonic
- Aug 15, 2013
My AKG K240 sextett's need a new cable and I have decided to add a Y split instead of keeping the original one side cable configuration. I have been reading over the DIY posts for recabling and I have assembled a list for the things that I will need. Hopefully I can get suggestions on the parts I chose so I can get stuff ordered. As of right now the only thing I have is the cable which is 10ft of Canare L-4E6S. For the plug I chose a NEUTRIK NP3X-B 1/4". At the Y split I am going to heat shrink the split, then twist a pair of wires to each driver. I am going to heat shrink each pair with 3/32" 2:1 wrap and then cover them with 3/16" nylon multifilament. From the Y-split down, I am going to use paracord. Do I have to cut the outer layer from the Canare cable for the paracord sleeving to fit? All my options seem like a pretty basic set up from what I have been reading but just wanted other people's opinions about what I have chosen to do and use. Also I was wondering if instead of going straight to the 1/4" plug, could I add a mini XLR female and then make a XLR male to 1/4" plug cable. So it's sort of like an Xbox cable where it can disconnect. Just for aesthetics really but if it will damper the sound quality then I won't do it. The plugs for the XLR set up would be Neutrik NC3FX-B and Neutrik NC3MX-B. For the Y split, should I split off the main cable and shrink wrap like I wanted above or would cutting 2 12" pieces from my 10ft cable be better so that the cable is the same thickness from the plug to the cans. What do you guys think?
Plug : Neutrik NP3X-B 1/4" or Switchcraft 35HDNN/Canare F-12 for a 3.5mm
Cable : Canare L-4E6S.
Y split : 3/32" heat shrink after the Y-split then heat shrink the center Y-split with 1/2" heat shrink.
Above the Y split : should I twist two cables and heat shrink then nylon multifilament over or use the 2 12" pieces of the Canare L-4E6S instead and connect them together.
Cable wrap : No more techflex, looking at paracord 550 now. Do I need to strip the cover from my Canare L-4E6S. and slip the paracord sleeve over?
Possible mini-XLR : Neutrik NC3FX-B and Neutrik NC3MX-B. (Male/Female)
Hopefully I made sense on what I want. I am not too sure on the shrink wrap sizes but yea. Let me know guys. Thanks!
FrozenPanda
- Oct 8, 2012
Anybody?
I'm looking to build a data/charging cable to charge my android phone. Does anybody know where to buy USB A and micro-USB B connectors? Would these work?
microUSB-B
USB A
Also.. How many wires are needed? is quad cable sufficient? I see that the A connector has 4 points while the micro has 5.. do I need an extra wire for data or something?
Anybody?
PXSS
- Mar 13, 2011
T
Those would be just fine and a quad cable is enough. The data sheet for that micro b you posted only has 4 contacts
Anybody?
mvrk10256
- Jun 24, 2013
What is the best source for clear low impedance copper wire. I bought some cheap 24G cable on ebay and my 10ft cable has an impedance of almost 8 ohms..... :O
I want something like OCC copper cable that doesnt cost $2/ft. Cause for 3 channels I need like 30ft....
PXSS
- Mar 13, 2011
Are you sure?? 24AWG copper wire should have a resistance of .257 ohms. Makes me think that I should start checking my own cables...
Ummm, I would suggest buying Mogami W2534 and stripping out the 2 clear conductors for a cheaper alternative. I know there's a site that already sells just the clear conductors but for the life of me I can't remember what it was.
mvrk10256
- Jun 24, 2013
Ya. I measured other cables and they were all around 1 ohm. Which makes sense due to my crappy HF multimeter. But all 3 channels rang in around 8 ohms. Stripping Mogami would be an option but it seems like a pain in the ass.
Total: 13 (members: 0, guests: 13)
