Paladin79
Previously MOT: Cables For Less
Thanks @Paladin79 . The reason I ask is that @PLUSSOUND says they use Type 6 lizt, which must be custom made for them, as I cannot find it anywhere is headphone size. Cooner Wire has it, but smallest is 9AWG. Cooner has a 22 AWG type 5, but when I sent them an email enquiring about samples and pricing, I got no response. I should probably call them.
I seriously doubt what they are calling type six equates to what New England Wire calls type six but I have no way of knowing. The fiber core is used on some cables to insure the round shape but it also keeps all bundles on the outside of the cable. If you read the uses for what New England Wire is producing, you will not see any audio applications so it gets tricky when you are not comparing apples to apples. I have seen closeups of some chinese Litz were you can see several bundles of wire, if a bundle runs down the center of the cable, it is not likely that all wires reach the outside surface equally nor are they as concerned if they do not. You are trying to limit skin effect when using high frequencies and keep the signal traveling on the inside of the wires as much as possible. You have less worries with audio frequencies so more than likely it is the proximity effect that can help litz wire when used in audio applications. What I have was made in Russia, it is not bundled and each strand may well indeed be exposed to the outside since it was made for specific applications. I like to see country of origin whenever I buy such things, it really should appear on the product.
