Hi! I'm new around and need some help to build my own cable for the Audeze LCD-X.
The goal is to get a mini 4 pin XLR female terminated in the LCD connector and two small cables:
4 pin mini XLR to ¼ and 4 pin mini XLR to 4 pin XLR.
1) I have no idea what kind of wire to get, I want something affordable but good quality, no snake oil.
2) I can't find any seller of the connectors to the LCD model. Any help here?
3) I'd like to know which brands sell good looking ¼, 4 pin XLR connectors and spliters, something a bit fancy would be nice.
4) I'm not yet decided if going sleeved or not. What are the mechanical differences between the two?
Any answer to any of those questions would be great!
I’m sure plenty of people will jump in here, but I’ll take a swing. First, there’s a really good resource on
building your cables here. The trickiest part is soldering the “jumper” on the mini-xlr connectors. If you need two, just buy four—give yourself some room for mistakes.
1) Wire: I’ve always liked
Canare L-4E5C. Some folks like
Mogami W2893 because all four wires are different colors. They’re both balanced microphone cables. The Mogami has better shielding, but depending on what your plan is, you might end up stripping that off anyway.
2) As for connectors, I’d personally go with Redco for the
mini-xlr and Neutrik for the
large xlr. Neutrik is pretty much considered the “slick hotness” connectors.
3) If you want more “fancy” connectors,
Double Helix makes some nice full size XLR, and they’ve got some cool y-splitters too.
4) Sleeve or not to sleeve. A lot of folks will strip the shielding off those four-conductor microphone cables and do a “litz braid” instead. The litz method will help reduce interference. However, with short cable runs, (5 ft.?) it shouldn’t be a problem. If you’re planning on a longer cable run, just keep the shielding on and strip your wire at the y-split. I prefer the litz method because it makes the cable lighter and more flexible, but it’s up to you.
