Paladin79
Previously MOT: Cables For Less
Sounds interesting. I was thinking of cotton or silk sleeving. Looks great, but can get dirty easily.
Stuff like this from PlusSoundAudio is very nice:
http://www.plussoundaudio.com/diy/components.html
Black, White, Silver available.
Paracord and shoelaces are also good. I've used TechFlex Nylon Multifilament with good results, but it can be a bit noisy.
You can search eBay for "BRAIDED NYLON SLEEVING tech flex" and find some 25' lengths for under $5, which might be good to experiment with.
If the wires are looser int he sleeve, they will be more flexible and less noisy. Too loose and it feel weird.
DoubleHelex Cables has "pure white cotton sleeve", but i gotta wonder about the durability of the stuff.
https://doublehelixcables.com/product/dhc-pure-white-cotton-sleeve/
parts Connexion has "pure silk tubing"
http://www.partsconnexion.com/tubing_silk.html
I have no personal experience with this stuff, but it looks interesting. Not cheap
@Paladin79 - can you post a link to an example of what you are referring to? I think you posted a pic of some purple stuff a while back. I'm always looking for something interesting.
I will try to post a photo when I get back to my office. There is no link to an example, I have my specs for what I had made but those will only be in the product description if I go with this fabric/braid.
I had a pretty good idea what you were referring to Allan and I generally go in my own direction on this type of product. I want something that will tighten down and conform to a cable but lacks the microphonics of nylon mesh or plastic.
