Another thought is to build a short 3.5 mm female to quarter inch male cable. Braid the wires,make it pretty, use quality connectors, and save a bit of wear and tear on the equipment jack you would be plugging in and out of. I have fashioned several of these for my own use because I do not like to use adapters unless absolutely necessary. It is also good cable building practice. Another method is to use four pin mini xlr male and females and use these at the end of longer cables. I have some for balanced equipment, 3.5 mm, quarter inch, whatever I need. Rean (Neutrik) makes some very good quality parts and they are my first choice. I am constantly changing and trying new equipment and the four pin mini xlr helps me a lot but may not be for everyone. Said connectors lock into place and there is a small release tab so they are a good solid extension to leave on a cable.
