Hey thanks so much for your help. I sent you a private message but I got a limit of 2 so I'm not sure you got it or not.
I would go with Mogami 2983 and take the wires out of that, they're 26awg. You technically can leave the cables inside and just solder 2 to ground, but part of the fun is taking them out and braiding them or putting paracord/techflex over them. For 3.5mm adapters I would use a Neutrik adapter or if you want to go fancier you could use a Pailiccs adapter. As far at the female jack I'm not sure if you need one that solders on but if so this is a good one 3.5mm Stereo Panel Mount Jack https://www.amazon.com/dp/B000ML4A2Q/ref=cm_sw_r_awd_MD8avb0D9NM5X
If you just need the adapter I think Neutrik also makes female 3.5mm
I think I'm looking finally at the Mogami 2534 because I like a thicker wire better! I think I will also leave the sheathing on the wire because I like how it looks.
I really like this:
http://i.imgur.com/4IMpYym.jpg
Would you say that's the 2534 or 2983? It looks quick thick actually now that I'm looking at it...
Right now I have Icemat Siberia V2's and the wire is quite thin...and it bugs me lol.
When looking at the paracord/techflex options, what do you usually choose for the sizing? Like I saw the 2534 is 6mm in diameter, so does that mean I need a sheathing that is 6mm, or should I go for something smaller so it's tighter?
And how do the plugs work for cable sizes? Do I need to choose different adapters if I go with the 2534 vs the 2983? How do I know which adapters fit which cables?
As for that female connector you linked, I actually need one that will be like in the picture I showed above. Basically I'm gonna make a cable with a female on one end and a male on the other exactly as shown in the pic. The headphones I'm getting you can see here:
http://headphonescout.com/wp-content/uploads/superlux_hd668b/18-superlux-hd668b.jpg
As you can see they have a male 3.5mm jack sticking out of them, so I need one end of my cable to be a female so they can connect together.
Thanks for the help!
Elliott
