Pingupenguins
Member of the Trade: BTG Audio / Q Audio
I'd have to agree with everyones opinions. PTFE wire is pretty stiff. I played with that stuff a while ago and decided mogami cable was way better. Canare works too if you can't find mogami.
23awg wire in a ptfe sleeve is probably less flexible than stock
somewhere between stiff and not very flexible at all lol
my fave akg cable i use is 28 awg 3 conductor (any more is just for looks)
braided and sleeved in 550 paracord super flexible
a,good choice is mogami 2799 innards its a bit more flexible
i think you mean shielding when you say ground
the shaft wire is the ground and is necessary most of us remove the sheilding
and just use the inner conductors
I've made a couple cables for my Q701s. Not sure about the wire gauge, but I used Mogami W2799 stripped to the four conductors, sleeved with 95-lbs (type 1, I guess) paracord from Paracord Planet, then braided in the round style. The one I use now is made from type 2 Litz 100/46 (i.e., 100 strands, 46 AWG(?)), and the same paracord and braiding.
I use two conductors twisted together for the grounding. Didn't have a problem getting it all into the Redco mini-XLR. I use Neutrik NP3X plugs at the TRS end.
The most important thing to know about the AKGs are the reversed signal pins on the mini-XLRs. You can verify this by testing the stock cable with a DMM. I've posted in here about the pin outs on the mini-XLR, so I'll let you find it, and not misquote myself. Just test continuity between the three female ends of the mini-XLR and the TRS.
Apologies if you already knew that, but it seems worth mentioning.
Good luck![]()
Thanks Arty McGhee. The stock cable is quite flexible and I would like to make something almost as flexible. My first DIY cable was made from a Viablue EPC-4 cable with just a syntethic sleeve. The shielding of the cable went to the ground of course. But this cable is very stiff and not very comfortable.
Is it possible, if I use 23AWG cable or smaller if I find, to use it bare inside a cotton sleeve? Or do I need the plastic tube? I couldn't find a cotton sleeve as small as 22AWG or similar....
Thanks ThurstonX. So two conductors are of course for L + R channel, and the two left over conductors you use for ground? I guess the first conductor is just for the looks, as 2x 25AWG f.ex. is quite a lot for just ground?![]()
Making a 25ft cable for HD650
At that length, shielding might be worth your time, hard to say. If the cable is running past other electronics and such, then yes. You solder one end of the shielding to just the TRS/XLR ground that goes into the amp, not to the headphones as well as you could cause a ground loop.
I'd keep the Canare as is with the shielding already done and wrap it in Techflex if it's not too laate...
20-22awg is probably fine from anywhere as long as it feels flexible enough, also consider doing higher strand counts of the Canare if you have enough (8 strand or so).
Nope, haven't tried fusing...
Now somebody come in and correct me on my advice XD.
Welcome to the forum...I will try to answer your questions one by one, based on my experience thus far in cable building:
1) There are several cable suppliers on eBay that ship worldwide from Japan, China, USA, etc. They are fast, efficient and you can get the supplies fairly quickly. You also should check Amazon uk for a lot of the connectors, heat shrink suppliers, etc.
2) Same as number 1 above. Also, you want to stay in the range of 24AWG to 26AWG. I think 28AWG is small for your HDs, so 24 or 26 AWG should work well for you. As for the cable type, you need to skim this thread and see the different types to determine what you like. For example, do you want clear cabling (see through) or do you want to sleeve it in Parachord?
3) The Y-Split can be made either: 1) Heat-Shrink 2) Buy a connector such as Via-blue or DHC (Double Helix Cable)/others 3) Leave it as is without covering, or 4) get creative and make your own
4) The best way to learn braiding is to check youtube - Search for "3 and 4 strand braiding" videos and learn from them
My advice, spend a few hours on the thread. You will learn a ton and avoid costly mistakes down the road. Search the web looking for supplies, sketch out what you think you want to do, come here with questions.
A lot of great people here that wanna help.
Cheers
---EDIT:
I thought of one thing that might help you learn braiding:Buy cheap 20AWG-24AWG wire from your local hardware store that is 16 feet or more. Cut 4 strands at 4 feet each, practice with this cheap cabling until you crack the braiding to your liking. When you go to the actual cable, there will be less errors and better confidence to get it right on the first go.
This might a huge long shot but it's sort of my last resort.
I have a pair of Sennheiser G4ME One headphones. My cat managed to chew the cord enough to make them not work.
Now I tried searching for replacement cables but found nothing, after posting on reddit/r/headphones someone pointed me towards this thread. I'm not really looking to dive this deep into the HiFi thing and really only want my headphones to work again. I only really use them to game.
Is there anyone in here who would fabricate a replacement cable for me, and how much would you charge for something like that.
Also, if someone could maybe point me towards a shop in Orlando that might do this type of work it would be greatly appreciated. I would not need any fancy cable or something non-standard, just if someone does do this work I'd like to get in touch with that person.
Fellow cable makers, found this supplier today, they sell "cloth-covered" cord http://www.sundialwire.com/clothcoveredwire.aspx#category
It's a bit over kill but looks nice.
