DIY Cable Questions and Comments Thread
Aug 20, 2013 at 9:42 PM Post #136 of 10,590
Really? which makes sense as thats whats on the DX100.
Thanks as I need to make a mini coax to coax cable
could be wrong but pretty sure.  The other type is just an rca connector but the iBasso looks like its a mono 3.5.  Just remember for coax you also have to solder the sheild for ground.
Aug 21, 2013 at 12:18 AM Post #138 of 10,590
I... can't seem to overcome the paracord... I keep attempting it every night and just can't seem to sleeve the wire. I tried electrical tape and teflon tape. It just sleeves for a little bit, and then doesn't move in any further. I can pull out the wire and see that the tape is still in place, so wires aren't snagging.... So annoyed.
Aug 21, 2013 at 7:46 AM Post #140 of 10,590
Thanks
Aug 21, 2013 at 7:50 AM Post #141 of 10,590
Ok so just to be sure you are kind of "worm bunching" the paracord on to the wire arent you? I mean you just arent trying to push the whole length into the cord without any massaging/bunching? So you push the cord onto the wire and bunch it up and then grab the front section of the bunched cord and pull it on over the wire (if this makes sense)
Aug 21, 2013 at 8:35 AM Post #142 of 10,590
Need to make a mini-coaxial to coaxial connector.
Does anybody have a diagram or sketch on how to solder this?
I believe its a 3.5 connector to an RCA connector
Aug 21, 2013 at 1:31 PM Post #144 of 10,590
how do you do RCA to 3.5mm?
you use two RCA connectors for each? and divides the covers in the middle?
You only need two wires for a coaxial SPDIF cable - wire the tip of the 3.5mm mono plug to the tip of the RCA plug with one wire, and then sleeve of the 3.5mm mono plug to the sleeve of the RCA plug with the other wire. When I've built my own, I've used Belden 8216, one brand of a 50 ohm 1/8" coaxial cable. The generic cable type is RG174A if you can't find the Belden brand. The tip is wired with the inner conductor and the sleeve is wired with the shield.
https://www.tessco.com/products/displayProductInfo.do?sku=98180&eventPage=1
http://en.wikipedia.org/wiki/Coaxial_cable
Aug 21, 2013 at 1:43 PM Post #145 of 10,590
I did not understand ... I want to make a cable like this: 2 RCA to 3.5mm (stereo)
Aug 21, 2013 at 2:25 PM Post #147 of 10,590
Sorry, I misunderstood and thought you wanted to build a SPDIF coaxial to mini-coaxial cable. The description from liquidzoo is correct for a 3.5mm stereo plug to dual RCA.
Aug 21, 2013 at 2:44 PM Post #148 of 10,590
Amazon in all of its amazingless just recommended this seller to me: Paracord Plannet
Does anybody buy their paracord from here? It has a decent selection at good price. Specifically the Combo Crafting Kits.
The only noted difference is "[size=small]Type III Commercial Grade parachute cord (almost identical to the Mil-Spec without the higher prices)."[/size]
[size=small]What does this mean exactly, they are both 550lb.. Does one fray more easily?[/size]
[size=small]Mixed reviews on amazon though.[/size]
Aug 21, 2013 at 2:55 PM Post #150 of 10,590
I buy all of mine from SupplyCaptain, mostly due to the fact that I normally buy Type 1 cord for sleeving wires.
I have bought mine from EBay-All Outdoor and More. It is relatively the same price other than the kits.
According to reviews, people didn't get quite the kit they were expecting. The reviews for this item were more solid.
I bought Type 1 from Michaels but still can't figure out how to thread it properly. tried using a paperclip but couldn't keep the wire on with tape. A guide with pictures would be much appreciated xD.
