kiteki
aka Theta Alpha 1
aka Alpha Zeta 5
aka Alpha Zeta 6
aka Nanocat Systems
And many other aliases
- Jun 7, 2010
I don't know what others have said, but if the THD, IMD, and noise aren't low, they will definitely be relevant to the final sound as perceived by people—unless maybe it's just 2nd harmonics that aren't really low. One of the points of my previous post was that the SWR may look similar on paper, but may actually be hiding significant and audible differences because the y-axis is zoomed out so much, and the effect of the FR is so dominating on what the squiggles look like. I wouldn't really say that the SWRs are nearly identical, but that the graphs look similar from a geometric point of view. Anyway, how about 40 Hz square waves, 2000 Hz square waves, and so on?
That could all be well and true, 40Hz and 2000Hz square waves, and the geometric point of view, I don't disagree there, however given that perspective - the data we currently have at hand and the level of introspect required to find the differences between the MMM and LCD-3 renders the current data pretty useless.
There are more examples like I can't stand the Sony XBA-4 due to not having crossovers, this is not in the data. I just look at the technology and usually find all the correct answers there. The data also doesn't tell you the size, distance or shape of the transducers. Let alone it doesn't show you resonance (like brass, titanium, wood etc.), perhaps that shows up in CSD ringing, however only looks like a negative effect.
Then, the data doesn't test for source transparency, how the transducers "ink" the signal with their own sound - all the time.
Let alone I haven't found any common pattern in the data of BA drivers, dynamic drivers, ortho and stax, there really should be a common pattern for these, since it's so audible within 5 seconds via listening, right?
FR is useful for volume across frequency (=colour balance), THD+N for noise (like a weak TV channel signal) - IR for what, refresh rate, attack and decay, resonance? Idk.
A lot of people are attached to the idea data is total in all fields of science, so if it's not on paper = it doesn't exist. I've tried to hit home this point with examples like subliminal advertising or human reaction times and it's just not working in[size=small] "› [/size]Sound Science[size=small] › [/size]Dilemma".
Originally Posted by mikeaj /img/forum/go_quote.gif
The point you make about today's notions of transparency being based on currently-available playback gear has some merit though. We have imperfect transducers mucking up all our listening tests. Maybe they're masking issues that would otherwise be audible. I think some people are taking the whole transparency idea too seriously anyway.
Exactly.
Thanks! Now I'm leaving this thread.
