itsborken
- May 22, 2007
Sorry to hear about your problem. It sounds like an opportunity to improve the DIY skills if you are that concerned about sending it back. The cover can't be glued on that securely or it could never be fixed. I'd imagine once cracked you'd be able to glean a battery part number/manufacturer and google for a replacement. Drain the battery/circuit completely if you are going to go that route. Best of luck either way.
Originally Posted by boomana /img/forum/go_quote.gif If I thought I could get a better battery by sending it back, I would. I'm now nervous that it will die, and sending it back is an undesirable option for many reasons. Because the top's been glued on I'm not sure I know any one who would be able to replace it for me, even if they knew how to work with that kind of battery. I like how the amp sounds, but this is yet another problem. |
