Dethonray Pegasus SG1 - BT DAC/Amp Combo
Apr 2, 2024 at 11:12 PM Post #692 of 697
Can you guide me on how to update it?
And any improvement in battery life?
You can download all the tools and user manual, then follow the operation guide to execute step by step. However, be careful not to modify the default settings below. It would be difficult to succeed if these configurations are incorrect.
Apr 3, 2024 at 3:19 AM Post #693 of 697
If you follow the directions on the user manual through his site it is pretty straightforward. I have done it a couple times. With this update I really don't see much change tbh
Thank you..!! Will keep you updated
May 5, 2024 at 1:41 PM Post #694 of 697
Started using Wavelet often. Sounds good with Pegasus through ldac 990kbps.
May 6, 2024 at 10:56 AM Post #697 of 697
