Dethonray Dtr1 Prelude high resolution player
Jan 11, 2021 at 9:48 PM Post #1,606 of 2,074
doctorjazz
There is no Dana, there is only ZOTL!
Reviewer for The Headphone List
Been up and down in this, but the latest is that I let Anson know it was going to cost as much to ship the unit from the U.S. to China as it would cost to buy a new unit, so I wasn't going to send it to him for repair. I expected that was the end of it, bit he emailed me information on someone in California to whom I should send it. Haven't sent it yet, likely in the next few days. So, hope had been rekindled...
Jan 12, 2021 at 3:25 AM Post #1,607 of 2,074
AndrewADler
Adler
My DTR1 have died too. It have sung his last song just before Xmas. It have discharged and refused to turn on after charging. That's all. Power button doesn't do anything too. The Reset button and keyboard shortcuts do not help. Unfortunately it died just 14 months after I bought it and now warranty period is over.
Jan 12, 2021 at 5:02 AM Post #1,610 of 2,074
AndrewADler
Adler
I don't think these DAPs are very reliable, am I wrong? Is there a reason why the same problem occurs?
I think DTR1 quality is poor. This is my second player. I used it very carefully but it died. The first one periodically froze, and I had to revive it with the reset button. I changed it under warranty. So I have a bitter experience although I liked the sound of my player.
Jan 14, 2021 at 7:30 AM Post #1,612 of 2,074
fabio19
italy
But do you use the photo taking WITH AN ADAPTER, or do you use a "normal" one that you bought separately?
Jan 14, 2021 at 8:42 AM Post #1,615 of 2,074
F700
between drivers
What do you mean by "special"?
The wall charger is custom designed with +8.6V (600mA) and -8.6V (300mA) outputs for quick charging the internal higher voltage batteries. You only can charge the DTR1 with this specific wall charger. It’s not possible via USB.
Jan 14, 2021 at 9:05 AM Post #1,619 of 2,074
robstah
Athens, GA
I'm thinking a lot of the issues comes from the QC of the charger... Mine works but does have a tiny hum with load applied. The charging circuit is inside that charger to save room for the double batteries and smaller size of the unit.
