Prophet293
- Aug 19, 2014
I was just wondering, if I was to use the DA-10 as a DAC only, how do I bypass the amp section? Use aux out?
Denon does not have optical and it is limited to 24/48 and can act as an amp. It seems like they are so confident about their tuning that they believe it should not matter as they will win due to how good they tuned it...
Here is a brief introduction: http://av.watch.impress.co.jp/docs/topic/20140909_662329.html
The translation of that article says,
"when the iPhone / iPod connection it is up to 48kHz / 24bit."
I presume that that refers to when the included 30-Pin to USB or Lightning to USB cables are used. However, is this also the case when the Camera Connection Kit or Lightning to USB Adapter are used, in the same way that the Cypher Labs Theorem 720 DAC and Centrance HiFi-M8 are both still limited to 96/24 and not 192/24? @audionewbi
or anyone else: can you confirm? The following resources make no mention of it:
Product Information Sheet:
http://assets.eu.denon.com/DocumentMaster/MASTER/Denon_DA-10_EN01.pdf
Quick Start Guide:
http://assets.eu.denon.com/DocumentMaster/MASTER/DA-10EM_ENG_QuickStartGuide_IM_v00.pdf
Instruction Manual:
http://assets.eu.denon.com/DocumentMaster/MASTER/DA-10EM_ENG_CD-ROM_IM_v00.pdf
Thanks for the comparing the Denon DA-10 against the Chord Hugo. I would also like to see it compared against the Sony PHA-3 (as someone else has said) and PHA-2, as well as the upcoming OPPO HA-2.
With cck and onkyo app it can support DSD 5.6 no issue at all.
I have stopped using the da-10 and will return to it in a months time to see if I still feel the same about it.
Yes all that s supported too.Thanks for the swift response, @audionewbi
, but what about with 24-bit/192kHz FLAC / ALAC / WAV / AIFF?
It is a pity the Sony line is not compatible I was considering going that way myself .
Apple appears to have abandoned the audiophile market but perhaps will pick up again next year , I think their failure to update the Ipod line this year may be a good sign .
Otherwise it does leave the market for the DA10 quite narrow as they lock out many of the daps on the market. I do believe all digital inputs are passed through the AL32 processors , going from Denons flow chart and the fact that they function as low pass filters for the dac .
