Hi Guys,
Thanks for input and recommendations. My budget is max around 500 euro for the amp so a lot of proposal would not fit by quite a margin but there is not much I can do about it at this stage.
Quick question - on example of suggested here Yulong D100mkII. It has frequencies range of 20hz to 20 khz which narrows massively of what D7100 can reproduce - am I right or am I missing something or not understanding correctly? Will it limit of what D7100 can do or does it work in some other way which I dont understand (sorry for noob question).
Thanks keep it coming guys
Also I am considering product which will be little known on this forum but from what I know it is quality one which has all the characteristics of giant killer
, but will it be a good match for D7100 in your opinion from technical point of view (impedance, current, voltage, amperage and so on - it is a transistor type AMP BTW). According to this formula 20 * log[(Zmin+Zamp)*Zmax/(Zmax+Zamp)*Zmin] everything should be fine (the result is close to 0.25db) but what about the 1,5W RMS on headphone out for 32ohms impedance of D7100 which this AMP supplies?
One polish review which was done by pro reviewer said it is a great match for D600 which he was testing in this review (it was actually more expensive version of this AMP but with very similar sonic characteristics, just mostly different power section from what I understand)
The AMP which I am thinking of is called Black Pearl -> here is the link to company page and product description (scroll down the small window to get to pricing and specs)
http://earstream.eu/page/66/Black+Pearl/l/en
Here is about the only review from user other then from country of AMP's orgin - Poland:
http://www.head-fi.org/t/642742/black-pearl-headphone-amp-from-ear-stream-loaners-thoughts
Let me know what do you think guys.
Thanks
