- Aug 8, 2013
...it is this small piece of metal, you can see it better from the outside when folding the phone...
Actually this piece is on the left and right can, and if you move it a little it makes this sound on either side. It is just slightly more loose on the right side, so it makes this clicking sound when shaking the phone. I do not feel disturbed. If it wasn't mentioned here I wouldn't have recognized it.
If you feel disturbed, you could try to apply a very little bit of grease (e.g. Shimano Workshop Grease) inside the gap on either side of that metal piece; That should dampen the "rattling" well enough.
I found the rattle/clicking to be very annoying, to the point that I was being careful not to move my head while wearing the headphones. So I tried the above suggestion and applied a tiny bit of grease. Problem solved .
!!!HOOOORAY!!!
