In my experience the best sounding mods for the D7200 are similar to those on the TH900.
1. Use the
Chinese pads, without the plastic pad mounting rings, but glued to the housing with small stripes of double sided adhesive tape. This alone will make the D7200 sound much better IMHO. Note that I have tried about 3 pairs of the Chinese pads, and they all sounded slightly different, so YMMV.
2. Optionally replace the damping material from the cups to very light filling of Twaron Angelhair like on the picture. I stress on _very_ light filling. Overdamp it and the sound becomes dark really fast.
Take care when re-mounting the wooden cups: first start to turn the screws lightly in reverse direction until it clicks (finds position), then lightly turn them in, then press the cups to the housing with the fingers while securing the screws with more force, in order to not put stress on the threads. It is absolutely important to use the same thread in the wood as before unmounting. Patience, light hands, small movements, sensitive torque control.
Edits:
1. With the Twaron in the cups, also the original pads sound good. A bit deeper and slightly darker tone than the Chinese pads which sound a bit more vivid and more "lit up" with colors. It depends on music which one I prefer, but I think the Chinese pads would appeal for more people, even though "deeper tone" is generally desirable.
2. By using good quality (denser, thicker) double sided adhesive, I can take off the pads without marks on the housing, and put them on several times without losing grip. The plastic pad mounting rings are retired for good.
