whitedragem
- Feb 26, 2010
you will want to defeat all processing on that AVR (I had it and would NEVER use it for audio (snob alert))..After weeks of reading reviews forums and along with many emails I have decided to go with the Ares ii. I’ll like to thank Alvin for taking the time to quickly answer my question, along with the member of this forum who offered help.
Bought this mainly to be used in my iem system. I feel it with the Xduoo ta20 and Mest mk ii it should have a nice warm sound signature and be different than the dac I am using.
I‘m also going try it on my home system, have a feeling it fit right in with my older collection of gear. I believe good gear last, so home system it Denon AVR 3803 7.1 klipsch speakers with a svs subwoofer. I mainly use a Pioneer 563a sacd/dvda player as a source with home system so I’m curious to hear what the Ares ii using hi rez source sounds vs the Pioneer.
Now that the hard choice been is made it’s just finding some descent cables to hook it all up.
if you use the all channel stereo mode, your best bet to keep all your speakers engaged, it would be a waste of the ares…
to that amp, whilst cables might make a subtle difference (or a noticable difference if you spent ‘big money’), the point of a nice external amp is lost.
the problem with AVR sound is that they achieve ‘good sound’ by using lots of speakers and DSP control and RE-EQ for their soundfield.
Two channel setups care about room placement of the individual speakers..
Back in the nineties when AV processors started to come to market, and for the decade that followed, flagship parts could easily be ‘upgraded’ by using the OLD stereo amplifier in the users setup to keep the front left and right functioning..
In a setup like that, playing with cables might be more worthwhile.
As someone who uses an Anthem processor and powered using flagship surround amplifiers (as power amps) (double+ the cost of the Denon you are using), I find that setup ‘unlistenable’ for two channel audio (nicely mastered stuff)(fine for ‘mass market/made for radio compressed recordings etc),..
I say this simply because I have heard the Denafrips in a nice two channel system (second hand parts <$2K total budget(not including DAC) which also including a dedicated new CD transport), and the location of some test track samples were placed beyond any DAC I had tested prior.
Given the best surround amps wouldn’t put out 1/3rd the soundfield depth of ‘that basic two channel system’ (using an entry level stereo amp), what ‘richness’ and layering and ‘benefit‘ you would gain from a nice DAC, would be mostly lost to surround amp and likely a room untuned for two channel speaker setup.
Save money on the cables (and I AM a ‘cable guy’).
Don’t get me wrong.. I completely agree with notion of old parts are great value(eg the SACD player you use was fantastic way to get into the format),.. but I have an old processor -a Proceed AVP2 that is more hifi in ‘dolby surround’, than the Denon is with lossless ‘trueHD..
The Denons best trick is the Re-Eq (subwoofer is TIGHT with the main speakers and awesome steering), but none of that circuitry can be engaged in the AVR, otherwise you are simply doing an Analogue to Digital pass on your nicely Digital to Analogue’d sound (from the Denafrips).
It is still an exceptional DAC, and literally it threw sounds 80feet back in the soundstage that, prior I had only heard 50-60 feet back ‘at best’.. (and it makes every instrument sound natural, at all volume levels, and doesn’t run out of steam when the full band kicks in (like some DACs)).
Grab the Denafrips, sure, but I wouldn’t ‘go crazy’ on nice cables for in into the AVR.. (beyond a basic price point).. again,.. I say this as a person who has many sets of nice cables,.. but AVRs just aren’t a good investment for DACs and nice cables. (Seperate processors and power amps are a ‘different story’, but need to be big cost to match even fairly budget ‘2 channel’ kit.).
Having recently rotated out a Yamaha Aventage amp (or a range of flagship surround amps from ‘earlier’ in history) as doing main duty in my two channel setup (my valve monos need a service), it amazed me how basic budget two channel amps just ‘did better’. (ie a Denon DRA-700ae)
The benefit of having an AVR in place was being able to look at the speaker re-eq plots and moving my main left right speakers until they achieved ‘close to flatline’ without needing to re-eq (and then swapping in a ‘stereo amp’!).
not trying to be bearer of bad news (the Denon AVR sounds musical if you have no other reference,.. just trying to save ye come coin on cables..)
edit: vs the Pioneer DVD player; if you gave up the ‘multi channel input’ on the surround receiver(best way to possibly bypass internal decoding/ADC) it will blow it away.. as would a NuForce IconHD -a budget DAC approx a decade old)
