Darkvoice 336i & 336SE Tuberolling PartII
- Thread starter HeatFan12
still not see clearly about how virtual zero connected. should be looks like this ?
Here read this post, it is addressing the same issue: https://www.head-fi.org/threads/darkvoice-336i-336se-tuberolling-partii.348833/post-16182719
I really hope the designer hasn't been telling people their tubes are defective when it is the amp. It's very disappointing that so many of these have been sold with this issue in place.
bcowen
He is soooooo high maintenance!
Yes, I am. And soooooo worth it.
bcowen
I know, here is his license plate.
LOL! Someone tried to copy my plate...mine has a Carolina Blue background.
Just to make sure, it's fine if I put two 200 ohm resistors in parallel on each heater pad if I don't have any 100 ohms at my disposal? I'm almost done with my extremely long rebuild, just need to put the heaters back in, those resistors for the center tap, and to wire the pot.Here read this post, it is addressing the same issue: https://www.head-fi.org/threads/darkvoice-336i-336se-tuberolling-partii.348833/post-16182719
Edit to add: since I'm removing the Fitz mod at the same time, I'll be able to speak a little bit to the hum reduction by comparison.
adamus
- Feb 29, 2008
200ohm will be fine if the wattage is ok, may not need to parallel. i used 220r back in the dayJust to make sure, it's fine if I put two 200 ohm resistors in parallel on each heater pad if I don't have any 100 ohms at my disposal? I'm almost done with my extremely long rebuild, just need to put the heaters back in, those resistors for the center tap, and to wire the pot.
adamus
- Feb 29, 2008
Super helpful, thanks! I'll probably then just use one each of my 200ohm 1w resistors rather than paralleling.
Deceneu808
Before and after. Still won't work properly.
Paladin79
Previously MOT: Cables For Less
Sorry to hear that, not much to lose if you heat them again and apply more solder.Before and after. Still won't work properly.
qingcai
- Jul 4, 2007
thanks for reply, I have not disassembly the whole amp yet. so not sure about the LED pcb schema and don't understand why when connect like your addressed . why need 2x2k resisters paralleled with exists on the led PCB.Here read this post, it is addressing the same issue: https://www.head-fi.org/threads/darkvoice-336i-336se-tuberolling-partii.348833/post-16182719
Deceneu808
Yeah I'll apply a little more and see what happens. If that doesn't do it I'll probably donate them or something.Sorry to hear that, not much to lose if you heat them again and apply more solder.
Paladin79
I do not mind helping with some things.
I replaced the solder in some very old tubes before and while solder can go all the way around a wire, it does not mean you have good contact. I used flux a few times and finally it worked.Yeah I'll apply a little more and see what happens. If that doesn't do it I'll probably donate them or something.
qingcai
- Jul 4, 2007
