cddc
- Dec 7, 2009
I wasn't expecting any substantial difference going from the Fiio E10(not E10K) to the modi 3 since the modi isn't a high-end DAC but I'm surprised how much more clear it is. I also need to lower the Darkvoice knob about half from where it usually was because it's noticeably louder. I wonder if it wasn't powering my HD600s enough and the quality was suffering because of it. Not to say that it used to sound bad, I just think it's better. It could just be a placebo but at the very least I'm happy with my purchase.
edit: I keep thinking about it and the DAC doesn't really "power" the cans (from what I understand that's the amp's work) so not sure why I need about half the volume now.
Yes, your DAC won’t power up your cans directly. The difference in loudness you perceived was caused by the different output voltage levels from your DAC’s.
My guess is that the output voltage level from your modi 3 DAC to your DV amp is much higher than that from your FIIO DAC.
Some amps have a high/mid/low switch to select the input voltage level from DAC’s. My BHC amp doesn’t have the switch, not sure if DV has it or not, but my Dynaudio monitors do have the switch.
If your amp doesn’t have the selection switch, simply adjust your amp’s volume knob to an appropriate level, it is as simple as that, not a problem at all.
