Darkvoice 336i & 336SE Tuberolling PartII
Jun 25, 2018 at 4:04 PM Post #1,576 of 14,518
I, ve been using a GE 5998A power tube & suddenly it started un seating itself after I turn off the amp
If re seat it works fine,what could be causing to lose it seat?
Have you removed/reinstalled the power tube a lot?
You may need a socket saver.
Jun 26, 2018 at 1:01 PM Post #1,580 of 14,518
Are you using HD600/650 with DV ? I am yet to try my HD650 on DV, but with the other easy-to-drive cans i tried so far, there is continuous audible hum in the headphones. I can even hear the hum directly from the amp, if i move my head close to the amp
Yes, I am using both my 600 and 650 more with my DV than the Jot as the DV is way more punchier irregardless of genre I played. I notice that I have also hum for about two weeks of my use, using Sylvania VT-231 and TS 7236, but the hum is gone now. Totally silent even even me not playing anything from the source. So as stated by some here, it will probably gone after burning-in the tube for some time. Before this, I ignore the hum as it is not noticeable when there is a music playing.
Jun 26, 2018 at 1:06 PM Post #1,581 of 14,518
I see. hopefully hum will go away in my case as well after some time
Until then i will try and use the HD650 so the hum wont bother me much
Jun 26, 2018 at 1:10 PM Post #1,582 of 14,518
Yes, use you 650 as the 600/650 paired great with OTL amp such as this. As per advise from most of users here, Russian made tube seems always have a hum so avoid those.
Jun 26, 2018 at 3:03 PM Post #1,583 of 14,518
Try this: Pull the power tube (big one) and flip on the DV and walk away. Come back 3 days later, hum will be gone.
Jun 26, 2018 at 3:48 PM Post #1,585 of 14,518
Jun 26, 2018 at 7:13 PM Post #1,586 of 14,518
If you can get the NOS USA Tung-Sol's, they should not hum. None of my tubes (that I have tried) hum in the Darkvoice. (Except those Tung-Sol re-issues)
Jun 27, 2018 at 12:34 AM Post #1,587 of 14,518
Love this combo.
3646380244217511985.jpg 5342699926465935708.jpg 6901878434469637104.jpg 8033188450077801710.jpg
Jun 27, 2018 at 3:13 AM Post #1,588 of 14,518
As mentioned, I do not have hum now after the tube burn-in of about 3 to 4 weeks playing for 3 hours a day.
Jun 29, 2018 at 6:30 PM Post #1,589 of 14,518
I have been an advocate of the 6F8G tube for use in the Darkvoice earlier on this Forum. I have since switched to a Bottleneck Crack. After trying many tube configurations I still find that the 6F8G/6C8G provides the best sound as a front-end tube. I especially favor the Tung-Sol 6F8G. These tubes are still relatively cheap but seem to go up every day. It takes a bit of effort to get to the end sound - requiring 2 adaptors. However, in the 336 you would only need one adapter since it uses the 6SN7 tube on the front-end. I have attached a picture - highly recommending this configuration.
