Dan Clark Audio Stealth Review, Interview, Measurements
- Thread starter jude
1) It should, but it depends on how loud you listen.Hey Guys, I have a couple questions regarding the Stealth.
1) How hard are these to drive. Would a ifi Signature Blue be okay to use with them when traveling?
2) Do these leak out a lot of noise? I read/saw somewhere saying that these don't isolate sound much, so they wouldn't be great to use in an office-like environment.
2) They don't leak (again, depending on how loud you listen), and isolation is very good in my experience.
Thanks! I don't really listen to my music loud at all, so that's good to know. To put in perspective, I tested the out the Expanse using the ifi Signature at a shop and it drove it fine (at least when it comes to volume).1) It should, but it depends on how loud you listen.
Andrewteee
#1 -- I gave up and only use the Stealth with a high power amp -- it sings so well with it!Hey Guys, I have a couple questions regarding the Stealth.
I use a DCA Aeron 2 Noire with a Chord Mojo 2 for traveling. That said, I believe Dan Clark is an advocate of the Mojo 2 with the Stealth/Expanse because it's design enables it to power such headphones (I can't tell you why).
1) I use a ifi Go Blu with my Stealth when I'm portable, and it works wellHey Guys, I have a couple questions regarding the Stealth.
2) They actually don't leak out that much at all. They are much better than other closed-backs I've tried
The Stealth are a bit more efficient than the Expanse, you should be good.Thanks! I don't really listen to my music loud at all, so that's good to know. To put in perspective, I tested the out the Expanse using the ifi Signature at a shop and it drove it fine (at least when it comes to volume).
johnwillmclean
The Mojo 2 is designed to current double with a low impedance load.I use a DCA Aeron 2 Noire with a Chord Mojo 2 for traveling. That said, I believe Dan Clark is an advocate of the Mojo 2 with the Stealth/Expanse because it's design enables it to power such headphones (I can't tell you why).
duas2noites
Does someone here is pairing Stealth with Feliks Envy? Need some feedback about it.
plumpudding2
Pretty fun thing to try since the Stealth takes eq so well: I used Jaakko Pasanen's autoEq to equalize the Stealth to match the Susvara.
Quite effective in my opinion, the soundstage actually becomes wider!
I have this theory that a mid scoop around 2khz has an effect on soundstage width, as 3 flagships renowned for their wide stage (Susvara, Meze Elite and Abyss 1266) all share this scoop.
The treble also gains quite a bit of "air" some might find lacking in the stock tuning.
Chord designed the amps explicitly to support loads as low as 8 ohms with a linear power scaling function. In other words they're made to be happy on lower impedance headphones. Some amps just crap out below 50 ohms, especially portable gear.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
801evan
Got to try a broken in Expanse and begrudgingly, as I usually don't agree with DMS or anyone in the Headphone show, it does sound muffled. BUT only in respect to the Stealth. Compared to the Susvara, Expanse is still more intelligible albeit a bit wanting on the upper mids so in this duel, it doesn't sound muffled...but it sounds mumbly.
Chain aune streamer + aune clock/ zen stream airplay/ neo stream airplay to tt2/pro iDSD to vioelectric amp with custom silver occ bnc and XLR.
When using occ copper bnc and xlr, Susvara sounds like the better headphone. Easy choice. The Expanse sounded too muffled, filed off on the top, fatiguing on the slam. Silver chain opened up the Expanse and showed the inherent resonance issues on the Sus.
On a souped up m17, (medium or high gain, whichever it was at max volume), Stealth is still better for me. On this case and the other chains, Stealth always sounded better and even more open than the Expanse.
The only case where Expanse sounds better than the Stealth is when m17 is on battery mode. The blacks are too lifted so the Susvara sounds underwhelming while the Expanse's sound is more preferred.
So....this is consistent with my apprehensions on the Expanse when looking at the graphs and from Dan's +2.5dB @175hz advice. The midbass bump on the Expanse masks the sub bass extension and thus, gives a smaller sound field than the Stealth and makes the Stealth a more open can experience than the Expanse. The midbass bump also encroaches into the lower harmonics of vocals so a lot of speech is veryyy mumbly.
Lastly, I have the RME on a souped up psu and it handles the Stealth very well and doing that +2.5dB @175hz EQ yields the same mumbly muffled sound. I tried lifting the 8-12k range but...nothing sounds good on what I was chasing as some needed highs. So on a good system, Stealth is the best choice that doesn't need any EQ at all. If Expanse sounds better on your chain, you know you need to work on your signal chain.
I would replace Expanse with Stealth in your phrase IMO
801evan
I rest my case.I would replace Expanse with Stealth in your phrase IMO
Daniel Johnston
I can confirm Mojo 2 and Stealth work well. I maxed out the 20HZ and 125HZ shelves (for fun with some EDM). Incredibly deep and non distorted bass.The Mojo 2 is designed to current double with a low impedance load.
lmpine
- Nov 4, 2007
Any experience comparing the Mojo2 vs. the Hugo2 and the Stealth?I can confirm Mojo 2 and Stealth work well. I maxed out the 20HZ and 125HZ shelves (for fun with some EDM). Incredibly deep and non distorted bass.
